Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 12-09-2004, 01:03 PM
NSCricket NSCricket is offline
Reset Service Engine Soon light
My Service Engine Soon light came on on my 97 Saturn SL2 shortly after an oil change and hasn't gone out. The car works perfectly. Someone suggested resetting it to see if the light comes back on. How do I do this? I see in another post to take the battery cables off and touch them together for 15 seconds......
Old 12-09-2004, 03:09 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
I don't believe they need to touch together. Disconnect the negative for about 10-15 minutes then reconnect it the computer should reset.
Old 12-09-2004, 11:32 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Reset Service Engine Soon light
i would get it read, go to your local Autozone or parts store, many will pull OBD-II codes for free.
Old 12-10-2004, 07:55 AM
whosgreg whosgreg is offline
Disconnect the battery for 10 - 15 mins will clear the codes or autozone can clear your codes for free. It is definitely not a good idea to touch both connectors together.
Old 12-10-2004, 12:50 PM
Re: Re: Reset Service Engine Soon light
I would love too but I'm in Nova Scotia, Canada and I believe they charge for reading codes. If the light comes back on I'll take it in then. Thanks everyone! By the way, I LOVE my Saturn and will probably make my next car a Saturn too....
Old 12-13-2004, 10:35 PM
97sc1sleeper 97sc1sleeper is offline
Send a message via MSN to 97sc1sleeper
Re: Re: Re: Reset Service Engine Soon light
Your service engine soon light means that there is something wrong with your exhaust sensors in your car..the smallest thing is that it could be that your gas cap isnt on tight enough and getting more serious could be a sensor or smog/ pollution problem.. get in touch with the dealership.. that light comes on a lot if you've modified the car as well.. for my car its because of the cold air intake.. sometimes water splashes up on to the p-flow and gets in to the sensors..drive your car around for 30 mins then your golden until it gets damp again.
