Old 12-09-2004, 12:07 PM
Wister06 Wister06 is offline
Send a message via AIM to Wister06
Need Help on what i should get to Lower My 90 Honda Accord!!!
I'm New with the modification of of cars.
I just bought a:
1990 Honda Accord LX (4 Door)
I looked at a few body kits for it and was satisfied with 1 i had seen.
I was told you should lower your car before you purchase your body kit, so you are able to tell your clearance.
Is this all i have to do to lower my ride???
Purchase Coil-Over or Lowering Springs And Shortened Shocks?
Or will i have to Modify my A Arms and and linkages???
I would greatly appriciate it if You would help me with this and/or give me a web sight on were i could go to get more information about it!!!
Thank You,
Wister06
Old 12-09-2004, 12:38 PM
94hondaacc 94hondaacc is offline
it depends on how much you lower your car. example eibach prokit does not lower your car a lot but it is better than stock, you should change your struts also because the factory struts would go bad if you leave it on. if you drop it lower such as the sportline springs then you would need a chamber kit, so that your tires waste evenly.if not you would begin to see uneven wear on your tires. if your are going to put a body kit and drop your ride i hope you live in a place with out ramps because you will break your body kit doing simple things like goin in to get gas, or on the concrete stump in some parking lots. hope this helps good luck
Old 12-09-2004, 03:32 PM
Re: Need Help on what i should get to Lower My 90 Honda Accord!!!
Thanks alot man !!!! Yea i live were its not to bad(New Jersey) theres ramps and what not but i know a few friends who have body kits and they have no problems!!! Thanks again It was some great advice!!!
Old 12-09-2004, 03:34 PM
Mojeans69 Mojeans69 is offline
It all depends on where you live, and what kind of drop your looking for? for instance I live in Mass, and we do get snow here in the winter, so I went with the coilover suspension. With this I am able to lower my car up to 4" for the summer, and bring it back up for the winter. got some tein's off ebay $850 . You can get just the coilover sleeves off there, for cheaper, but you'll end up buying new struts soon anyway, so why not just get the whole thing in one purchase. The factory struts will blow with any kind of performance springs. So you shouldn't go the cheap route, and just buy the springs . remember you get what you pay for.
Old 12-13-2004, 09:08 AM
Yea i like your idea i think i'm gonna go with the CoilOver Springs and make the winter to summer changes as need thanks for the great idea!!!
Old 12-13-2004, 11:18 AM
JimmyzGarage's Avatar
JimmyzGarage JimmyzGarage is offline
With Koni Yellows, there are 3 different perch settings. With lowering springs, you won't have to compress them to change the perch setting. Doesn't give you 4 inches of range like the other more or less like 2-3 inches of range.
Just don't get the cheap coilovers. The springs can't take the impact and will bottom your car out all the time.
Old 12-13-2004, 05:04 PM
So Koni yellow's are good coilover springs that will hold up???
Old 12-14-2004, 09:42 AM
Re: Re: Need Help on what i should get to Lower My 90 Honda Accord!!!
Sorry man, Koni yellows are gas adjustable struts to use with lowering springs. The position for the spring perch can be moved by moving the clip to a different slot on the strut. It is not a coil-over system. Unless you shell out the $$'s for coilovers, don't get any cheap ones...for like a 100 for the set on e-bay or something like that.
Konis are a great product, when used with a good quality lowering spring, like eibach, neuspeed, or H&R. I've installed a set in my buddies integra and it made the car corner like a slot car (which means it was fast).
Old 12-14-2004, 09:50 AM
Maple50175 Maple50175 is offline
Send a message via Yahoo to Maple50175
Come over to www.cb7tuner.com! We will help you get a good setup going!
http://www.cardomain.com/memberpage/467543
My sweet ride :-[
Old 12-16-2004, 12:26 PM
so should i go with skunk 2 coil-overs and a set of Koni Struts?
Old 12-17-2004, 04:54 AM
Huffa Huffa is offline
Just drive around with 3 heavy people in the car when you want it lowered. A couple sand - salt bags in the trunk will also help.
Old 12-17-2004, 11:12 AM
i don't care about how low it is i want it to handle and stick to the road !!!
