Old 12-09-2004, 11:12 AM
karmacae
Guest
Posts: n/a
Question sterring wheel controls
Hey there, is there anyone that can tell me if I can change out my radio in my 1991 grand prix, and still be able to use the controles on my sterring wheel?
Old 12-09-2004, 11:16 AM
AKWE-gt AKWE-gt is offline
Re: sterring wheel controls
yes, they have some kind of kit for it. i jus don't know know who or where you can find it.
[size=5]
Old 12-09-2004, 11:29 AM
karmacae
Guest
Posts: n/a
I have another problem, my low coolent light comes on, I check the the coolent level and everything seems fine. any ideas????????
Old 12-09-2004, 01:28 PM
theblurr87 theblurr87 is offline
Send a message via AIM to theblurr87
i dunno if 91's are any different then the new ones but try this post
http://www.automotiveforums.com/vbul...d.php?t=310658
its also a good idea to search before you post. good luck
'99 SE (l36) 125k mi.
FWI | ZZP HVTB St. 1 | WP UD Pulley | 3" DP/HF Cat/U-bend Del.
Old 12-09-2004, 01:31 PM
karmacae
Guest
Posts: n/a
thanks, sorry about that
Old 12-09-2004, 01:51 PM
Chazman Chazman is offline
Is your coolant level sensor in the overflow tank ??
I have found that they tend to stick - they have a little float on them.
I find if you smack the side off the tank right were the sensor is, with the handle of a screwdriver they usually come free - just be carefull the tank is plastic don't use a hammer or any thing like that.
Old 12-09-2004, 01:56 PM
karmacae
Guest
Posts: n/a
I will give it a try.... thanks
Old 12-27-2004, 02:14 PM
StinkyWinker StinkyWinker is offline
Speaking of Sterring wheel controls, does anyone know if a guy can change the light bulb in them, and how????
If anyone had done it before, I would appreciate an advise. Thanx.
Old 12-27-2004, 03:32 PM
BIG-L's Avatar
BIG-L BIG-L is offline
Here is something you can do when your bored.
Tools used:
Pair of sidecutters
Pair of needle nose plires
A Jewelers screwdriver (flatbladed)
A sharp pointed scribe
One Cinnamon Toast Crunch Breakfast bar
One low wattage soldering iron (unavailable for pic)
First remove the module from the steering wheel. This may be kind of tricky. There are no bolts or screws holding it in, it should just pull out. There are wires attached to the back of the module, a clip in the middle of the harness separates the harness from the module. The harness looks like a CD-ROM audio cable connector. Once removed from the car you will have to pull back some of the stickers/labels on the unit, so it can pull apart freely.
Once the stickers and such are moved for free access to separate it, use the jewelers screwdriver to push in the tabs and carefully separate it into the pieces below.
Here you can see the parts disassembled. The front with the two smaller buttons, the main volume button, the pin the volume button rocks on, and the back of the unit with the circuit board. Make sure to not loose the pin. it will fall out easilly as the only thing that holds the pin in and stops it from going side to side is when the unit is back together.
The circuit board is held onto the back piece by a very tiny screw with a hex head. Use the needle nose plires to remove this. Be careful as to not let the plires slip off the nut and damage the resistor next to it. Take your time doing this. The red bulb that lights up the module is near the bottom. There is a red plastic cover over it.
The rear separated form the circuit board with screw shown
Be careful pulling the flexable plastic cover off of the light bulb. without that you will loose the red glow your modules have at night, and it will not match your pontiac interior lights. I was haste and tore the tip of my bulb cover off
Here is a picture of the new bulb. It is from Radio Shack: P/N 272-1092C. 2 per package. #7219 Micro Lamps. 12 Volts 60mA. Wire-terminal base.I have since found a closer matching bulb then the one from Radio Shack its from www.partsexpress.com P/N 070-265 and its 12 volts and 35mA VS 65mA aslo incase you mess up the red lamp cover the P/N is 070-090 they come in a pack of 10
The two lines represent the wires inside the bulb that hold the filament. at the top, how it curves to the right, that is how the bulb must point twords the bottom of the module (twords the two smaller buttons that are side by side)
The new bulb is in and soldered. The old bulb was removed by crushing it with the needle nose plires over a garbage can to catch the glass. Then use the soldering iron to heat up the solder joints of the wires left, and pull them out. The hot solder will seal up the holes once the wires are removed. Heat up the solder joints again, and from the backside stick a pin (or thin scribe) thru the hole to "pierce" it. Then solder in the new bulb and make sure the filament is in as described.
On the back cut off any extra leads left over from the new bulb installation. Only do this when soldering is fully completed.
Here is what it should look like once completed. Note how I repaired my bulb cover. When you put the bulb cover back on, it will be pretty loose as the bulb is smaller than the original. A small dab (very small!) of superclue to hold the bottom of the bulb cover to the circuit board will work great
Reassembly: put the circuit board back onto the back of the module, and put in the hex head screw. take the front of the module and assemble it with the volume button and the pivot rod. Flip it down on the table and take the back half and press them together and make sure everything lines up. Once together it is time for assembly back into the car. This is tricky. Find a friend with really small fingers, or use a thin screwdriver to make it easier. Take your time, and do not tug the wires too hard. The module has clips on the back that secure it into a rubber interface in the area where the back of the module meets the steering wheel. Start the car. Turn your lights on and if the modules light up...
Enjoy the Cereal bar!
Notes:
The "new" bulb will be slightly brighter than the stock one unless you use the one's from www.partsexpress.com P/N 070-265
If you have the time do BOTH sides for a uniform lighting scene.
Hope this helps you out!
~Larry~
Old 12-27-2004, 04:08 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Larry,
You need to write a book on Grand Prix fixes.
I'll buy a copy.
Old 12-28-2004, 08:45 AM
It couldnt be more detailed, Thanks Larry!!
Put me down for a copy of that book
Old 12-28-2004, 08:59 AM
Re: Re: sterring wheel controls
Originally Posted by kustomkid54
Larry,
I'll buy a copy.
i will too, but unfortunately by the time hes finished we'll all be driving in hovercrafts. theres just wayy too much that he has!
oh yea and as for the lighting on the controls, you cant really tell the difference. i did it in mine with the LED from radioshack and i noticed for about the first week, and i havent thought about it since, until now of course. unless you have OCD you'll be okay changing just one. however they do come 2 in a pack and ive already lost the other one so might be a good idea doing both at the same time
have fun and good luck!
~ Matt
