Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-09-2004, 09:42 AM
BrickBryan BrickBryan is offline
Grease Zerts
I've got a 99' Passport and am wondering how many and where the grease zerts are. I've only found two u joints on the ends of the drive shaft so far that have zerts. Just want to make sure I'm not missing any other ones.
Thanks in advance for any replys.
Bryan
Old 12-09-2004, 11:50 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Grease Zerts
you should have zero. I'm surprised you have them on the drive shaft? I know the trooper has them but not the Rodeo. Anyone want to peak under there truck to confirm (I've looked like 3x and have never seen them).
-Ryan
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 12-09-2004, 12:24 PM
they are on the u joints, not actually the drive shaft. I just want to make sure there aren't any other spots to keep greased besides the slip yoke and u joints.
Old 12-09-2004, 04:59 PM
rodeo02 rodeo02 is offline
Re: Grease Zerts
Your universal joints have probably been replaced. Any of the factory U joints I've seen have no zerks at all. There's not a single zerk anywhere on my 2002. You can 'massage' the ball joint or tie rod end boots to spread the grease around, or inject them with a bit'o grease with a grease needle. This helps the 'sealed' units last a bit longer.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 12-10-2004, 08:49 AM
mwt mwt is offline
All vehicles have been zerkless for several years.
It saves money when they are new and manufacturers feel that the life of a car is 100k and supply everything with "permenant lubed parts"
When you do any replacment there will be zerks on those parts
Mike
Old 12-12-2004, 06:01 AM
Letsrodeo's Avatar
Letsrodeo Letsrodeo is offline
Interesting.
My 99 Rodeo has at least one zert on the drive shaft u joint for the rear differential. I'll check the other end today.
As far as I know the factory supplied joints have never been replaced.
If you want something done right do it yourself two or three times!
1999 Isuzu Rodeo LS 4X4
American Eagle Series 149, 16X8
Toyo Open Country LT265/75R16
Rancho 9000
3" CP Lift, 3" PA Body Lift
Manual Locking Hubs, SuperWinch
Optima Yellow Top Battery
Custom Sound System
Shrockworks Rocksliders
Letsrodeo
Old 12-13-2004, 05:59 AM
Tom01Rodeo Tom01Rodeo is offline
Re: Grease Zerts
I thought so too until I got underneath my '99 Safari AWD van. This thing had 14 grease zerks in the front end. Took awhile to grease, but was glad to have them
