Old 12-09-2004, 08:37 AM
tha_prowler tha_prowler is offline
Send a message via AIM to tha_prowler
intake
whats the difference b/w WARM AIR/SHORT RAM and COLD AIR ?
thanx in advance
Old 12-09-2004, 09:32 AM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: intake
Next time search before you post... there are stickys at the top of the sub catagories when you click on them... this has been asked numerous times....
Intakes- I’ve had quite a few, which are normally called WAI;s and CAI’s (warm air and cold air) but the real names for them are long ram intake aka CAI and short ram intake WAI.
Short rams are usually more abundant, and from proof they run pretty much similar to long rams. A bit more quicker throttle response can be seen due to a shorter path and less bends to travel through.
Long rams are a bit more rare and are usually mounted down in the fender. Also another note, there are people always referring to “true CAI’s”…don’t know where the term came from, but the only difference between a TRUE CAI and a CAI conversion from a WAI, if the fact that parts came with the alleged “TRUE CAI” all in one package. The filters are all mounted in the same exact area, and the pipes travel the same path. Sometimes they charge you more for the name TRUE CAI depending on where you go.
Now, The reason I am leaving them to long or short rather than Warm or Cold, is that from measuring with a temp sender and gauge. There was a difference between the two of 4 degrees. Also another bit of note, it wa ian lacey or matt teske, one of the two dynoed a WAI at 9 hp, aem just dynoed one of their CAI’s at 8.6 hp. So does that mean WAI;s are better? No. they have just as many downsides as a CAI. Some people think the heat is extremely bad under the car, which is a myth, cause when the car is in motion air circulates under the hood. So basically you get the same air temp as a CAI.
With a CAI, the filter is mounted low, and in the summer time or sunny days we all know heat absorbs into the ground, and then…heat rises. The lower you have the filter, its still gonna take in warmer air. And also, COLD AIR, is normally what you read. However, use a bit of logic. The air is cold in the winter time, but in the summer, its hot outside. The air your intake takes in is only relative to the air temp outside. Sure dynos say this and that, but you also have to realize, they are in usually controlled environments, and also what a car gains on one car, can differ with the same part on another car. Meaning, I can dyno an intake on my car and gain 8 hp, take it off and give it to you and you may gain 10hp. Hell dynoeing a car outside and inside can make a differnce. The cooler it is the better the car runs.
There are plenty of companies to buy from. A lot of people swear by this and that, and that’s personal choice. Doesn’t exactly mean something is better, and there DEFINITELY isn’t a BEST. If any one claims that theirs is the best simply ask have you tried all the other intakes available? 9 times out of 10, prob not. I stopped after the rksport CAI, mantapart CAI, rsm WAI, mantapart WAI, and about 5 other self made intakes… there really wasn’t much difference in temp nor performance. Yea I wasted money, but I wanted to see what was all the hype. Back then intakes were around 200$ now they bump into the 300$ range. Some can justify it, I can’t. it’s a metal pipe with a filter on the end. Keep in mind every company out there has made a public printed claim that there intake is the best, or gives the most gains
AEM makes this claim: Outperform every comparable intake system on the market
http://aempower.com/product_intake.asp
other companys have made their claims, and while I will publicly say I don’t doubt ANY of them, one persons intake will always produce better results than another. On different cars results will vary. Don’t fall into the ordeal where company X said 10HP, but company Z make 7HP. It is quite and DEF possible, that Z may actually produce more on your car than X does.
For those that will want to make their own, save money and get pretty much the same performance. These sites will help.
http://www.airflowonline.com
http://www.ny-jbodies.org/forum/library/2200/intake.htm
http://members.aol.com/htown2200/intake.html
most of these are for a 2200 2.2 which can be done on a 95-97 2.2 as well, but if you have a 2.4, or 2.3 or ecotec, its really the same process, you just need to substitute different parts. Use the imagination. It’s a really easy job to do.
For those that will want to buy and intake, there are a few JBO locals and companies to check out.
Don’t get mad Chris, putting your registry/name out there.
http://www.j-body.org/members/agentomega/ he has produced some for the 2200. email him for other cars. They are of decent quality and a reasonably low price. Same as ToBoyz intakes.
And a few companies:
http://www.rsmracing.com[/url]
http://www.mantapart.com[/url]
http://induction-dynamics.com/[/url]
http://rksport.com/[/url]
http://carcustoms.net/store/[/url]
http://highrevmotorsports.com/catalog/default.php[/url]
http://www.howellautomotive.com[/url]
http://www.cavalierconnection.com[/url]
and even
http://www.ebay.com[/url]
those are some sites to get you started. If at worse, check google or WebCrawler, you will find more side shops that have them.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
