Go Back   Automotive Forums Car Chat > Oldsmobile > General Discussion
Old 12-09-2004, 07:17 AM
ger72867 ger72867 is offline
Digital Dash
I have a 85 Olds Toronado that has a flickering digital dash. It works off and on. My question is, can I have a aftermarket analog speedometer installed. I can live without the fuel and temperature gauges not working, but the speedometer is a must. Any suggestions???
Old 06-16-2005, 10:45 AM
SupremeCutlass's Avatar
SupremeCutlass SupremeCutlass is offline
Chances are that the base model came with the digital dash and the upscale had actual gauges. When mine was coming off and on it was bescause of a loose connection. Check the connection first, then see if you can find anything at a junk yard that will work
Old 07-09-2005, 05:04 PM
oldengrey oldengrey is offline
Re: Digital Dash
Is this the "Caliente" trim package? Actually an upgrade with interior/ exterior trim.
I have an '85 Toronado Caliente with the 5.0 Olds motor and had this prob and it turned out to be a bad chassis ground.
Hope this helps you.
