Old 12-09-2004, 03:59 AM
Mackab Mackab is offline
RTV for Inner Plastic Manifold Plenum
For those that have used the RTV trick to keep the inner plastic plenum from rattling, can you please tell me where you placed the rtv (i.e., the 2 opposite so called snap connectors) or around each individual intake. Plan on doing this evening if I get good word.
Old 12-09-2004, 05:45 AM
12Ounce 12Ounce is offline
Re: RTV for Inner Plastic Manifold Plenum
Mine was a case of "over-kill" I'm sure, but I put daubs around each passageway.... and then a bit on the bottom of the individual barrels when installing.
Old 12-09-2004, 02:30 PM
12 Ounce: I daubed a small amount around each passageway and a little around each barrel. Will check tomorrow after sufficient time to cure. Is there any worry about a daub breaking away and going down into the lower manifold?
Old 12-09-2004, 03:50 PM
Yes, I tried to make sure I used RTV in small enough globs so that it would likely stay in place ... or pass through the combustion chamber harmlessly if some did break off.
Old 12-09-2004, 07:47 PM
Windywoes Windywoes is offline
Send a message via AIM to Windywoes Send a message via Yahoo to Windywoes
Re: Re: RTV for Inner Plastic Manifold Plenum
Make sure that baffle is very secure. Read what happened to me on "'99 LX 3.8l Bad Engine Noise Indentified"
Old 12-11-2004, 11:30 AM
The RTV worked great! No more vibrations. Thanks all for the support!!!!!!
