Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-08-2004, 11:52 PM
rasec rasec is offline
Question eclipse 95 gs OBD II CODE U0E3F
Hello amigos,...someone knows what's this code means U0E3F, i went to autozone for check the engine light and this is one of the codes i got from the scanner, this code only can be tell by the dealership. The other codes are P0300 and P0422, about the last code i'm not sure if this is for the catalytic converter or for the O2 sensor at the back or behind the cat. i thing this is cause by the multiple cylinder misfire detected, not sure, any ideas. i'm working in the P0300. so please if somebody know what's U0E3F means?
thank you for your help!
Old 01-26-2005, 10:50 AM
royboy15931 royboy15931 is offline
Question
Could this be code for vehicle ID? What engine,tranny models do you have?
Old 04-17-2005, 09:55 AM
awbr awbr is offline
Send a message via AIM to awbr
Re: eclipse 95 gs OBD II CODE U0E3F
p0300 is (random/multiple cylinder misfire detceted) and p0422 is(main catalyst efficiency below thereshold - bank 1)
