Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 12-09-2004, 12:11 AM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
amps questios nand such
when i bridge my 2 channel does it basicly becoem a mono amp or what
Old 12-09-2004, 02:00 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: amps questios nand such
no it doesn't become a mono, well I guess it does sort of. But it can't handle the same ohm load that a Class D mono amp can. Most, if not all, 2 channel amps when bridged can only handle 4 ohms.
Empty Pockets Racing Member #1
Old 12-09-2004, 06:44 PM
well when i birde my amp it become to ohms and thats how im gonan run it
Old 12-09-2004, 07:52 PM
GScivic7's Avatar
what amp do you have? The amp itself does not become 2 ohms. The ohm load is dependent on how you wire your speakers.
I'm 99.9% positive that there is not a 2 channel amp out there that when it's bridged can handle a 2 ohm load. Have fun clipping your subs and blowing them.
Old 12-09-2004, 10:13 PM
Geeko Geeko is offline
Send a message via ICQ to Geeko
Bridging a two-channel amp can be a decent way to run a sub, depending on the amp and the configuration. If you run a bridged 2-ch amp with a single sub (Assuming 4-ohm load) you are esentially presenting a 2-ohm load to each side of the amp. If the amp is rated to be bridged, it will have a non-bridged, and a bridged minimum resistance rating. Going below that rating is almost a guarantee that you are going to damage the amp, the subs, or both.
For example, if you have a two-channel amp that is rated to be bridged to 2-ohms, you can bridge it, and then run 2 4-ohm subs in parallell to present a 2-ohm load to the amp. This means that each side of the amp is now handling a 1-ohm load. This example (crutchfield.com) will handle such a set up.
You will not find many amplifiers available that can handle a 1-ohm load per channel, so the above example does not apply to most situations.
Most two-channel amps that can be bridged are rated for a 4-ohm load when bridged, meaning that each side is being presented with a 2-ohm impedance; most bridgeable two-channel amps are like this. example (crutchfield.com)
In the more common case, the easiest solution is to wire one sub directly to the amp, for a 4-ohm load. Two subs may be wired in series, presenting an 8-ohm load to the amp (more stable for the amp, better SQ but less power). For a multi-sub setup, two sets of two subs wired in parallel may be wired in series (4/4=2, 2+2=4 ohms) to present the amp with a 4-ohm load.
Personally, I prefer to wire a two channel amp as two channels, and run 2 smaller subs, one off of each channel.
BD (Before Deer): Clean... Very Clean.
AD (After Deer): Nascar Ready.
Go Baby Go.
Old 12-09-2004, 11:39 PM
GScivic7's Avatar
Most 2 channel amps can handle 2 ohms in stereo though. Just run 2 4ohm DVC subs, wire the VCs in parallel and wire the subs to each channel.
This guy thinks his amp is stable at 2ohms mono though.
Old 12-09-2004, 11:54 PM
Re: Re: amps questios nand such
you could do that... i'm using equipment I already have, so the setup I prefer is the one I have besides, as long as you match your amp to your subs correctly, there is no reason to run them at anything but the regular-old 4-ohm loading- it's where they were designed to run, and is the most stable load for the amp (unless wiring in series).
Go Baby Go.
