Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-08-2004, 10:53 PM
a99eclipsedriver a99eclipsedriver is offline
Help Needed Please!!! Please Help!!!!
I need some help...hopefully someone can help. It's a 97 gst eclipse. To make a long story short. Someone had put brake fluid into my power steering reservoir. Yeah.... so now I got this **** in my reservoir. Is there any way to drain the reservoir? Is there anything, like a fluid or cleaner or something I can run throught to get this out? HELP!! I have no clue to what to do...PLEASE HELP!!
Old 12-09-2004, 12:07 AM
rasec rasec is offline
Cool try this...
hey body, who was the enemy....well try this...take out the connectors that goes to the power steering pump, and see if the fluid brake is not mix with the power fluid. in case you run the power steering you need to drain the fluid by using the same step is use to change the power steering fluid...i don't have time to tell you the process to do it...i'm going to bed so tired. Don't worry if brake fluid in your power pump steering, just don't turn the car. will cost you a lot money to buy many bottles of power steering fluid, but you know what, use transmission (if cheaper) fluid to help you to get out the brake fluid, but make sure is you can do this in your car. well i will laso ask to my teacher what idea he have. but try to search to solve your problem.
Old 12-09-2004, 12:14 AM
guess what!
go to autozone and buy a...i don't remenber the name of this kiy, but it will absorb the fluid from any tipe of liquid. works like a pump, you haev to press and pull, so one hose goes into the power steering pump reservory and the other hose goes where you want to recive the brake fliud....ask the autozone guy about this knid of pump...the cost is only less than $ 3.00 .; remenber always enjoy working in your babe.
let me know any results....
Old 12-09-2004, 04:59 PM
thanks...any more info
thanks for the info. Any more would be appreciated. Like the process of what you have told me (draining process). Please.
