Old 12-08-2004, 10:10 PM
G35turbo G35turbo is offline
Exhaust problem or is it normal????
I drive 97 vr4 and my cat-back is stock, and the thing is that my passenger side exhaust, there is nothin coming out. I mean no noise or air or nothing. I asked the dealer and they told me thats normal, but thats a dumass dealer talkin, i dont realy trust what they say.
What do u think is the problem or is all vr4s like that and that is normal??
Old 12-08-2004, 11:58 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Exhaust problem or is it normal????
Um is your active exhaust set to tour? That blocks of one side of the exhaust to quiet it down. Also the stock exhaust system is not true duals. When the exhaust is set to sport the flow out of the passenger side isnt all that much.
Old 12-09-2004, 07:58 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
There was a good write up the sport/tour settings on http://stealth.senecac.on.ca/archive.../msg00314.html
The drivers side is the sport mode exhaust, the passenger side is tour mode. The little mode switch on your dash activates a servomotor that is located on the side of the trunk on the driver side behind a small access cover. The servomotor pulls a cable which in turn goes to a valve on the exhaust system just behind the driver side rear wheel. You can see the valve operate by shining a flashlight on the top of the valve where an offset cam wheel is rotated about 180degrees by the cable. This valve often gets stuck in sport mode. It can often be fixed by removing the cable at the servomotor end and manually rotating the valve back and forth to free up the mechanism.
When the car is turned off, the servomotor switches the exhaust to sport mode regardless of the switch setting. THis is done to cycle the valve and prevent it from getting stuck. Otherwise, the valve does not move unless your RPM exceed 3,500 RPM, where it always goes to sport mode.
IF this system is working, you will definately hear a big difference in exhaust sound between the two modes. Also, at idle you should see exhaust gas switch from one side to the other depending on the switch setting.
Resistance Is Futile (If < 1ohm)
Old 12-09-2004, 09:49 AM
Where is the Switch on the dash??
Old 12-09-2004, 10:19 AM
Boosted1 Boosted1 is offline
The switch is to the right of the steering wheel. My Sport/Tour switch doesn't work, so smoke only comes out of my driver's side as well...until I come onto it, then it comes out of both sides.
Old 12-09-2004, 10:23 AM
What do u mean by "Until I come onto it"?
Is there anyway i can do it without the switch?
Old 12-09-2004, 03:01 PM
Say I'm driving at 40mph and I throw it into second and hit the floor with the pedal. My dad has been behind me and says there are two puffs of smoke and the car squats and takes off. So under high hp, both sides work. I wish I could tell you more about that switch, but mine has never worked.
Old 12-09-2004, 05:36 PM
I could not find the switch!!!!! Can u post a pic of were it is??
Thank You
crazy_quick crazy_quick is offline
Yea mine sounds nice when its on sport. My friend said "It sounds like your camming".
Old 12-09-2004, 05:37 PM
Is it on the streeing wheel or is it right side by the streeing wheel?
Old 12-10-2004, 02:09 AM
Igovert500's Avatar
blue + red light magnet
You don't have the switch...you have a 97, the switch was taken out pre-96(not sure exactly what year, but my car doesn't have it either).
It still does this automatically, but we cannot controller it. As was said, it isn't true dual exhaust, the passenger side only opens up under heavy acceleration. It's normal.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-10-2004, 03:19 PM
ohh ok.
