Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 12-08-2004, 09:04 PM
salem1oliver salem1oliver is offline
sub and amp for my z32
Is this a good deal, and is the sub included, I couldn't tell from the description.
http://www.cardiscountstereos.com/c...oduct+%23=ABP10
and is this a good amp and good price,
http://www.cardiscountstereos.com/c...uct+%23=A235HCQ
also will that first amp have enough power for that sub, or will I need to go with something more like this,
http://www.cardiscountstereos.com/c...ct+%23=A1300HCQ
I will be putting this in my 300zx with a Pioneer head unit. Any advice greatly appreciated.
Old 12-08-2004, 09:15 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: sub and amp for my z32
Dude your links are broken, for some reason they are cut in half so try redoing them. There is also a Audio part of AF located here http://www.automotiveforums.com/vbul...play.php?f=675
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 12-08-2004, 09:28 PM
Sorry, I had posted it in the audio section, but I wanted to get your guys opinions too...I think this should fix the problem with the links....
http://www.cardiscountstereos.com/ca...duct+%23=ABP10
http://www.cardiscountstereos.com/ca...ct+%23=A235HCQ
http://www.cardiscountstereos.com/ca...t+%23=A1300HCQ
Old 12-08-2004, 09:54 PM
Thourun's Avatar
Perfecct, just that I know nothing about audio lol.
1995 3000GT VR-4
Old 12-08-2004, 11:06 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
ok thats all very good stuff for the money...but i need to know what exactly you want to do...
do you want to take that bandpass enclosure with those 10" subs and run one of those audiobahn amps to it???
if so...you would want that 2nd amplifer assuming its a monoblock and the 2-10" subs are 4 ohms because you would wire both speakers into the one channel of the amplifier and it will evenly divide the 2 speakers with 300 watts RMS evenly. so it will max the subs out pretty nice...the first amp you linked us too will only put 35 watts through each speaker.
before you purchase any stereo equipment without a professionsal/experienced person to guide you through what your buying, i suggest you do some research on how stereo equipment works...i direct you here HERE!!!
ZedEx Crew Member #4
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
well, i have heard many a great things about audiobahn. like if you want a great stereo system, go audobahn. so if i was ever to spend some money on a stereo system, i would get audiobahn.
-Jared
ZedEx Crew Member #2
