Old 12-08-2004, 08:38 PM
bowhunter1432's Avatar
bowhunter1432 bowhunter1432 is offline
best oil?
i am getting an oil change this weekend on my 2000 blazer any ideas on what make of oil?
Old 12-08-2004, 09:24 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Re: best oil?
in the 91 w 161thousand im usin that new castrol gtx cold start it makes it run like its been runnin for 15 mins when you start and go it works real well and im at 1500 since the last change and im not noticing any drop in pressure like the last oil i usedand no smoking
Old 12-09-2004, 01:44 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: best oil?
Conventional Motor Oil: Castrol GTX 5w30
Synthetic Motor Oil: Mobil 1 Synthetic 5w30
Just don't use a fram or penzoil oil filter. Very poor filter.
Use a Purolator, WIX, Napa Gold or an AC Delco.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-09-2004, 11:34 AM
blazing blazing is offline
Re: best oil?
I use mobil1 i get from walmart for $19.96 5 qu.
with acdelco filter.
Old 12-09-2004, 03:29 PM
BlazerLT's Avatar
AF -Advisor
Re: best oil?
Yip, good choice.
Old 12-09-2004, 05:39 PM
thank you to all.
2000 Chevy Blazer
1995 Talon
Old 12-10-2004, 01:00 AM
rm54 rm54 is offline
I use Valvoline synthetic. Works ok for me
Old 12-10-2004, 01:22 AM
BlazerLT's Avatar
AF -Advisor
Re: best oil?
Don't put your good money with Valvoline synthetic, it is not a true synthetic.
Only Mobil 1 , Amsoil and Redline are true PAO based completely synthetic oils.
The others are marketing scams.
Old 12-10-2004, 09:51 PM
stid7566 stid7566 is offline
Re: best oil?
I have a really stupid question, but I just got an oil change done the other day and found that the door, where the the oil filter is, was down. We can't get it to stay up. On the door it says that the door must be shut for engine coolant. What can I do to fix it?
Old 12-10-2004, 10:48 PM
BlazerLT's Avatar
AF -Advisor
Re: best oil?
The oil filter door?
Old 12-11-2004, 06:39 AM
Re: Re: best oil?
LT, its the splash gaurd that covers the bottom of the motor, the door alows access to the oil filter, i would think your blazer has that two,
my lt blazer does the same thing sometimes when i don't tighten it anough,
Old 12-11-2004, 09:46 AM
troubles789 troubles789 is offline
Re: best oil?
I think the new trailblazers have this. None of mine do in the 90's.
Old 12-11-2004, 03:33 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: best oil?
Is your oil filter attached to the motor or do you have the remote oil filter cooler assembly.
Old 12-29-2004, 09:50 AM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: best oil?
Mine was slipping a bit when I torqued the 1/2 inch bolt back into it. Just get a replacement speed nut to clip over the backside of the door's frame where it bolts to - mine was stripped out and would let the door open a little even though the bolt was snug. Replacement of the speednut does not mean that you can torque the heck out of it, it will strip easily. Just make it snug and there should be no worries.
