Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 12-08-2004, 08:04 PM
jmeti000 jmeti000 is offline
blower not working!!
the blower for the a/c and heater would only work on high till recently. now it hardly ever works. maybe on rare ocassions it will come on by itself. anybody have this problem before and if so or if you have a clue what it might be pleeeeease help!! checked the fuses and all are good. and does the panel cover for the heater switches and radio just pop off??
thanx
jmeti000
Old 12-11-2004, 08:07 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
yeah, theyll just pop off. The far left one is a bit tough to get off. Did you check the relay under the hood for the blower in the power distribution box?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 01-06-2005, 05:45 AM
martaz martaz is offline
Re: blower not working!!
and if the relay in the power dist. box is good, check the ignition switch. Does everything else work? I had the same problem, thought bad blower motor but my turn signals would not work either, checked the ignition switch and lo and behold both started working again.
