Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 12-08-2004, 03:27 PM
96elipseracer's Avatar
96elipseracer 96elipseracer is offline
non-interference design
does any one know if Eclipse have a non-interference design (applies to Timing belt)
Basically, if my timing belt snaps it will only damage my engine if its a interference type, therefore i want to know if it's non-interference.
Old 12-08-2004, 05:50 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: non-interference design
interference type.. i've never heard the terms. but the way you descrided it. its interference
DSM geek
Old 12-08-2004, 07:13 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
im assuming you have a 2g. if you have a 2G NT its a non tnterference motor. if you have a 2G Turbo you have a interference motor.
post the year/model/mods of your car in your sig
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-08-2004, 08:37 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
huh ,please elaberate on this subject....?
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 12-08-2004, 09:41 PM
a interfernce motor means that if the timing belt breaks the piston and the valves can hit each other. a non interference motor means that the valves and pistons wont hit each other if the belt slips or breaks
-1stGenRocks-
Old 12-09-2004, 11:03 AM
Re: Re: non-interference design
Thanks! I heard that the 2g's (N/T) had non-interference design but just wanted to clarify! Really appreciate your help!
Old 12-09-2004, 06:06 PM
DreDay1984 DreDay1984 is offline
Banned
he wants to know if he has the crash motor= 4g63
