Go Back   Automotive Forums Car Chat > Ford > Contour
Old 12-08-2004, 02:26 PM
ThihiLady52 ThihiLady52 is offline
Angry Flasher replacement
Hi....I cannot locate the "flasher" on my contour...I have no turn signals or hazard light. I need to replace but cannot locate flasher.
I appreciate any info!!
Old 12-08-2004, 02:29 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
are we talking about the amber bulb in the front headlight?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 12-08-2004, 10:51 PM
Re: Flasher replacement
The bulbs and fuses are all fine its the flasher itself, is there anyway to fix that?
Old 12-09-2004, 01:35 PM
Re: Re: Flasher replacement
Im lost. Im thinking the "flasher" is the turn signal, but it must be something else. Can you explain it better?
"The CEG Nazi"
www.contour.org
Old 12-09-2004, 05:37 PM
Jason43's Avatar
Jason43 Jason43 is offline
I think she means the relay. I'm not possitive, but I believe it's in the steering column.
Just go to contour.org
1999 Ford Contour SVT
Old 12-09-2004, 10:50 PM
But.....WHERE? Can't locate it!!!!
Old 12-11-2004, 11:57 AM
The hazard lamp fuse is number 12 (page 236 of manual). The fuse box is located underneath the hood by the drivers side headlight.
"The CEG Nazi"
www.contour.org
