Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 12-08-2004, 02:48 PM
Devedander Devedander is offline
Xbox/PC trunk mount with subs
I am more a computer guy than a car guy so I was hoping someone can give me some input on this issue.
I would like to put either a pc or an xbox in the trunk of my car so I can access music and movies off the internal HD. Problem is I know HD's don't like to be vibrated a lot and sitting it in with some big subs seems to me likes it's just asking for trouble...
What are experiences or advice on this?
Do people tend to mound their PCs and Xboxs in the cabin or what?
Thanks.
Old 12-08-2004, 03:08 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Xbox/PC trunk mount with subs
I don't have first hand knowledge about this type of thing, but I have ready quite a bit about it. One of the things I've read was that even driving over big bumps or potholes can harm your PC HD. I've seen a lot of people using laptop HD's in cars, because they can withstand more of a shock without getting into trouble. And personally I've never seen pics of the PC mounted in the trunk with subs, always in the cabin. But with the xbox, I've seen it right near subs; on Pimp My Ride lol. Now as to what they did to have it not be effected by the bass, I don't know. But obviously it can be done. Personally I'd mount it either under a seat or fit it in the glove box. But that's just my opinion. Hopefully someone who has first hand knowledge will be able to help you better than I have. But if you do a google search I'm sure you can find info on the PC idea.
Old 12-08-2004, 03:34 PM
Geeko Geeko is offline
Send a message via ICQ to Geeko
it's better to keep gaming systems and computers in the cabin area, in terms of climate control, ease of power, and protection against foreign particles (ie dust). How long your HDD is going to survive in a car depends on how it is mounted, how bumpy your daily ride is, the make and model of the drive, etc. Typically, larger drives have higher vibration-caused failure rates, due to a higher density of platters and read heads.
BD (Before Deer): Clean... Very Clean.
AD (After Deer): Nascar Ready.
Go Baby Go.
Old 12-08-2004, 03:39 PM
Ack... Laptop drives are so expensive... I guess it would make mounting easier though as it would take less space.
I wonder if mounting the HD in the cabin somewhere and trying to insulate it against shock could help reduce damage due to shock.
I am thinking installed vertically (so that vertical shock does not drive the heads into the platter) and mounted on something with a dampening effect could help a lot... but I guess after all that a lappy HD might not be so bad an idea.
I just fancied the idea of 250GB of games and movies and being able to dump the optical drive all together.
Old 12-10-2004, 12:28 AM
KoHC KoHC is offline
I've been thinking of doing the same thing for a while now. Here are the information I have so far:
1. For PC, it'll be easier to use laptop than normal desktop. If you're just using it for movie/mp3... etc. A slower Centrino is a good choice. It consumes less power compare to Pentium 4 / AMD cpus. Which is really important if you want to run it straight from your car battery. If you have LCD screen in your car (or planning to purchase one) you can even search auction sites for laptop with dead LCD screens. Those defective laptops are fairly cheap and will reduce the power require to run the laptop.
2. Placing PC under the seat would give you easy access to the system and also reduce the viberation a bit. You might want to use wireless keyboard with build-in touch pad for mouse.
3. Install hard drive vertically doesn't really help out much. You can try that with your home PC (already tried, and didn't help much).
4. It's actually cheaper using modded xbox for everything.
Old 12-10-2004, 04:34 AM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
ok... now if you are wanting to install your xbox in your car, you can actually take your Xbox apart and stuff it in the glovebox, or you can actually tear into your center console and install the Xbox drive into the console below your radio.. and hide the HD, and control board somewhere below the console..
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 12-11-2004, 12:49 AM
Thanks for the input, I will keep all that in mind
