Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 12-08-2004, 01:01 PM
sam110264 sam110264 is offline
350 problem
I just put a 350 in a 67 chevy pick up. Engine runs great. But now, when the engine warms up the engine will idle very rough, then not idle at all. Higher rmps are great though. Seems like something is breaking down. I have electronic ignition on it, dual exhaust, edelbrock intake and carb, and electric fuel pump. I thought it was the fuel pump at first, but I have ruled that out. If anyone has any ideas I would appreciate it.
Old 12-11-2004, 10:46 AM
Re: 350 problem
Found the problem with the warming up and running rough. replaced the electronic ignition with another I had. Now I failed the emmissions test. Passes the loaded test with flying colors, fails the idle test. Any Ideas would be helpful.
Old 12-12-2004, 01:38 PM
CORE402's Avatar
CORE402 CORE402 is offline
Re: 350 problem
Have you played with the idle mixture screws at all? You could be running a little lean or too rich at idle.
1973 Camaro
AFR 195cc heads
CNC Motorsports 383 short block
Comp Cams hyd flat tappet
TH350
Dual 3" exhaust (LOUD)
Corporate 10 bolt w/ all new internals and axles
Old 12-13-2004, 12:20 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: 350 problem
can you post the numbers from the test?
Old 12-13-2004, 01:14 PM
CORE402's Avatar
Re: 350 problem
I am sorry I dont know what you are talking about?
1973 Camaro
AFR 195cc heads
TH350
