Go Back   Automotive Forums Car Chat > Buick > Century
View Poll Results: Where is PCV Valve on '91 3.3L Buick Century?
See drawing/schematic/picture at URL www.### 0 0%
Send email to me at (your email address) 0 0%
It is simple to find, all you have to do look for is.. 0 0%
Pay the $ and see a mechanic. 0 0%
Voters: 0. You may not vote on this poll
Old 12-08-2004, 12:46 PM
CotterPin CotterPin is offline
Cool PCV Location 3.3L Engine?
Hello Buick Community! Anyone know where the PCV is located on a 1991 Buick Century 3.3L? Yep, I've checked the schematic under the hood... ...but can't find anything that looks like the part, (which is: FRAM -- FV301; or, KEM -- PCV153; DEUTSCH -- PCV209; CHAMP -- PC146; WELLS/AMPCO -- PCV146.) If you know where a drawing/picture is online, etc., would appreciate. Thanks!
Old 12-08-2004, 01:01 PM
stoned_pimp420 stoned_pimp420 is offline
Send a message via Yahoo to stoned_pimp420
Re: PCV Location 3.3L Engine?
being honest i don't believe they have one, afterall i've went to mechanics shops and they can't even find it. If you find it let me know.
I'm back after a long mental evaluation and heavy medication!
If you can't be a good example, you can always be a horrible warning!
Old 12-08-2004, 01:26 PM
Talking Re: Re: PCV Location 3.3L Engine?
Thanks Stoned_Pimp420... When I find out where the pcv/replace location is -- I'll happily post it. Tryin' to remember what year the PCV & related emissions equipment became law/requirement. Maybe wasn't required in 1991? Optional then?
Old 12-09-2004, 07:51 PM
ltsnow ltsnow is offline
I found out where the PCV valve is located on my 89 Century (3.3L). It is adjacent to the alternator. You have to lift up the alternator (easy) and you will see it on the back side of the valve cover. Hope this helps.
Old 12-09-2004, 09:01 PM
tbaxleyjr tbaxleyjr is offline
I just got through replacing the PCV valve and the pre-formed gromet and rubber hose @ the intake manifold in my 1990 Century - I agree removing one blot, losening the other and swinging the alternator out of the way makes thie job a lot easier.
Old 12-09-2004, 09:36 PM
Smile Re: PCV Location 3.3L Engine?
HOWDY! and THANK YOU! to "Itsnow" and "tbaxleyjr" !!! I'll be replacing that PCV valve now. With appreciation, CotterPin.
Old 02-09-2005, 08:51 AM
Telesforo Mendez Telesforo Mendez is offline
a caution
When twisting and yanking out the brittle pcv valve hidden on rt side of intake manifold behind alt. don't repeat my mistake.Accidently tore the top grommet.The broken portion of the grommet that plugs into the plemum fell into the intake manifold and down into an intake valve chamber. Had to pull intake manifold and use a forcepts to extract it.
Old 02-09-2005, 10:24 AM
I've moved my alternator and still didn't find it. Is it that thing that goes into the front valve cover that just looks like a hose going into it? afterall my 1990 4.3L V6 along with every other engine I've seen it goes into the valve cover but if that's it on my car I can't get the dern thing out.
Old 02-11-2005, 08:49 PM
On my 89 Century 3.3 the pcv valve is tucked on the rt (passenger) side of the intake manifold. It is down low--hard to see & reach because of the wires and the alternator. Definitely had to remove the alternator & move wires out of the way. But it's there, probably never replaced before, since it was so hard to get to. The hose coming out of the front valve cover connects to the throddle body (I seem to recall). It is does not have the pcv on this motor as it often is on others.
Tork
Old 02-22-2005, 07:06 AM
jibbijib's Avatar
jibbijib jibbijib is offline
Send a message via MSN to jibbijib
I can look in my haynes manual for it, but i dont guarantee anything because the v6 3.3 in there is a "typical" 3.3 and it looks like a for engine, completely different from the gm. But i will Look and post what i find for ya stoned_pimp
