Old 12-08-2004, 11:40 AM
trf62 trf62 is offline
Service Engine Light
I have a Chevy s-10 crew cab that I purchased new. I hit the 100,100 mile mark the other day and the service engine light came on. I assume that this is a preset as I just had it serviced about 2,000 miles ago. How do I reset the computer or turn off the check engine light. I would like to reset it assuming nothing is wrong. If it comes on again I will take it in for service. I just do not want to pay to have them check it out, reset it and tell me nothing is wrong.
Thanks
Old 12-08-2004, 11:58 AM
vtmecheng vtmecheng is offline
Re: Service Engine Light
Disconnect the neg. battery terminal for 5 min. (usually do mine for 10 at of good measure). Then reconnect. Thats it.
Old 12-10-2004, 03:36 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Thanks
The service engine light is there to say you have a problem.
go get the codes read at autozone.
Do NOT clear the memory!
Also, the engine light does not come on to say you are in need of regular service like oil etc...
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-15-2004, 12:58 PM
general poot general poot is offline
Re: Re: Service Engine Light
BlazerLT is correct. You can get a key from Auto Zone and read your codes it will let you know if you are having a problem with alot of different sensors and other things. do not clear it until you have read your codes.
Old 12-15-2004, 02:20 PM
BlazerLT's Avatar
AF -Advisor
Or if he has a 1995+, they have a small handheld device to read the codes.
Old 01-13-2005, 08:59 AM
dblthebass dblthebass is offline
Send a message via AIM to dblthebass
i would just disconnect the battery and reconnect it and if something is wrong than it'll come back on, also did you hit a big bump? you might have knocked your o2 sensor loose it's happend to me a lot
Old 01-13-2005, 09:54 AM
mike1224's Avatar
mike1224 mike1224 is offline
Send a message via AIM to mike1224 Send a message via MSN to mike1224 Send a message via Yahoo to mike1224
it could be your O2, usually last about 100,000mi.
2002 Chevy S-10 ZR2
Originally Posted by balls_to_the_wall
Some people are alive only because its illegal to kill them.
Old 01-13-2005, 10:10 AM
Go get it checked out before clearing any codes. I know this has already been stated but some disagree. Figured a little push in the right direction wouldn't hurt. I don't believe chevy ever used the "service engine soon light" as a regular maint. reminder so get it checked out. BTW: What year is your truck?
Old 01-13-2005, 12:55 PM
BlazerLT's Avatar
AF -Advisor
What for, so you will never know what the problem is?
