Old 12-08-2004, 10:57 AM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
Headlights Dim
Hey, whenever I turn my AC on, or when i use my power windows, the headlights dim. However, they don't dim at all when running my sound system, even when the car is off. Any clues as to why? Should i start looking for a higher amp alternator?
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 12-08-2004, 11:01 AM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Re: Headlights Dim
Make sure that your grounds are good, and you have plenty of grounds from your frame to your battery. I added a 4 gauge wire just for extra flow. But AC/Heat will cause a drop in voltage. How good/new is your battery?
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 12-08-2004, 11:03 AM
icE_x's Avatar
Re: Headlights Dim
hmm not too sure, but i've had the car since beginning of july so i'm guessing at least a year old
Old 12-08-2004, 11:06 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Headlights Dim
Mine used to do that, I think its stoped sence I put on a 4g ground, like 4g4dstore did.
Old 12-08-2004, 11:38 AM
icE_x's Avatar
Re: Headlights Dim
is that the one on the valve cover?
Old 12-08-2004, 11:51 AM
Forunn Daberator
Re: Headlights Dim
Just get you some 4gauge wire and run it from your battery terminal to the frame then to the motor or if the terminal is big enough go from the terminal to the frame and from the terminal to the motor then from the motor to the frame
