Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 12-08-2004, 10:15 AM
RaenX RaenX is offline
How do I get my old radio out?
I've got a 1994 olds 98 that I'm trying to get the radio out of. I found some vague instructions online, telling me to remove 3 screws above the gauges, and 1 on either side of the steering wheel. However, there are only 2 screws above my gauges and none on either side of my wheel. Does anyone know where the screws are, so I can pop this thing out?
Old 12-12-2004, 12:10 PM
JBrill1970 JBrill1970 is offline
Radio Extraction
Not sure how close your's is to an 89' model but I had to take off the full dash panel center and bottom to remove the radio. In other words ALL the screws holding the dash panel on. Need to put the car in drive low and move the steering wheel all the way down to get the center piece out. If I remember right there are 6 screws across the bottom. Start with the top/center panel and take all the screws out. Remove the panel you will then be able to access the ones holding the bottom panel that are behind the middle one. The top/center panel has 2 places that are pushed in not screwed in careful not to break them when trying to pull it out.
