| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Autotrans problem
It has been a long time and i got the engine thing fixed, but i all still trying to fix the trannie. For some reason its stuck in 3rd or 4th gear and it takes a long time to accelerate. Some times it dies when i put it into D and start to move. I think because its putting a load on the enigne, kinda like tring to start moving a standard car in 5th. Anyways i looked at my TCM and there was a little burn spot on it. I am pretty sure this is my problem, unless one of yall might have a diffrent reason. I still cant seem to find a TCM down here.
![]() 95 GS-T 'cause everyone thinks they're right, and nobody thinks that there just might be more than one road to our final destination |
Re: Autotrans problem
Probably the TCU/TCM. I got a brand new rebuilt (i.e. never used since rebuild) one on DSMTrader for 80 bucks.
Kris 2012 Genesis Coupe 2.0t |
Are the 1st gen and 2nd gen TCM's interchangeable
i dont think so since the trans is different. write down the part number from your tcu and make sure that whatever one you get has the same number. mitsubishigraveyard.com and dsmtrader.com would be the first place i would check.
btw i got a ecu for 100 brand new rebuildt on ebay from a place that speciallizes in auto computers
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
almost had the same excite problem mine wouldnt shift up to 3rd so it could be the same it was the speed senser for me and also the tech wouldnt move but yeah just sayin it could be that i dont know where it was located because i went to the dealer
