Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-08-2004, 09:14 AM
riff22 riff22 is offline
clutch problems!!!
i have a 95 tsi. 2 gear sincro was out so i had a new one put in and since the tranny was out i got a new clutch and got the flywheel resurfaced. well when i got it back the pedal wouldnt come back up so i got a new master and slave cylinder, ran fine for a few days then found out that i had to adjust the linkage on the master cylinder and it was fine. well now the pedal actually sucks down to the floor, doesnt just fall sucks down. i bleed it many times and there is now air in the line. what could this be????
thanks
tyler
Old 12-12-2004, 07:37 PM
joemathews's Avatar
joemathews joemathews is offline
Re: clutch problems!!!
Are you losing fluid from the clutch master or slave cylinders? If not, it is most likely that the adjuster bolt on the pedal assembly needs to be adjusted. If you are still losing fluid, check the clutch lines for leakage.
1996 Eagle Talon
Old 12-13-2004, 09:23 AM
i think i got it fixed played with the linkage a lil bit and it seems fine well c if it happens again in a few days
