Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-08-2004, 07:31 AM
Striker2k4 Striker2k4 is offline
Co2 o N2o for Freezing Intercooler?
Hi everybody! nice Forum :-)
I thinking about freezing my intercooler using N2O or CO2.
What do you think could give me best results? N2O or CO2?
Which one produce cooler effect?
Thanks a lot!
Bye!
Old 12-08-2004, 02:36 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
What kind of intercooler are you running? water to air or air to air intercooler?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 12-08-2004, 05:27 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Personally, I would go with CO2, it's cheaper than N2O. Also, you could use compressed oxygen for the same effect and it is even cheaper to refill.
As far is results go, I don't think you see a difference between the three.
Old 12-08-2004, 08:25 PM
Reed Reed is offline
Send a message via AIM to Reed
Re: Co2 o N2o for Freezing Intercooler?
i would say go with n2o just because if your going to be spraying a gas under your hood (possibly near your intake) it might as well be a gas that is rich in oxygen. Im pretty sure co2 doesnt promote combustion. correct me if im wrong.
Cars are like music.
If it ain't fast it ain't shit.
Old 12-09-2004, 10:19 AM
psychorallyfreak's Avatar
psychorallyfreak psychorallyfreak is offline
Send a message via ICQ to psychorallyfreak Send a message via AIM to psychorallyfreak Send a message via MSN to psychorallyfreak Send a message via Yahoo to psychorallyfreak
uh...yeah.
didn't he just say that compressed O2 will have the same effect, and be cheaper than both N2O and CO2?
Or was I just seeing things.
And you're right about CO2, it doesn't promote combustion AT ALL. That's why they (used to) make CO2 fire extinguishers....
Old 12-09-2004, 10:59 AM
Thanks a lot for all yours reply.
I just bought a bottle of CO2, I coudn't find a N2O bottle here in Uruguay.
But now I've a bigger problema
Co2 bottle have 160 Bar pressure. I couldn't find a solenoid to this preassure
Can I reduce this pressure to 15 Bar and get the same cooling results?
I guess I coudn't...
Thanks a lot and I aplogise because my english is horrible !!
Old 12-09-2004, 06:11 PM
well i said it doesnt promote combustion because n20 does and thats a good thing to have your intake sucking up.
compressed oxygen would be the best choice, obviously, but im not so sure its the best thing to have under your hood, you know, in case you crash.
Old 12-09-2004, 06:39 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
N2O its self downt promote combustion. When Heat is added it decomposses into N2 and 02
2M N2O ----> 2M N2 + 1M O2
this rises the ammount of oxygen in the cylender allows more fule and there for more power.
N2O also is cold when it decompresses, as all things matter. This cools the intake charge. If yo uare going to use N20 to cool your intercooler, for its price, you might as well be shooting a 20-40 shot post intercooler. it will show far superior cooling effects.
CO2 does not promote combustion, at least not at the tempatures reached in your average ottocycle engine.
Pure O2 is more expensive than CO2 but cheaper than N20. however, pure O2 will make a haven for combustion. Not ideal. but if yo uwant to try it, you can have your bottle filled anywhere welding supplies are sold. the better idea would be oxygen inriched air. instead of the normal 27% Oxygen, its like 50% oxygen, yo uwill get the same effect, any oxygen that leaks into your intake will help you, just may raise combustion tempatures a tad.
or
you could jsut use compressed air, it wont be as cold as N2O or CO2 or O2 or O2 enriched Air....but it will be colder than the ambieant air tempautre. now im not saying have an onboard air compressor, im saying bottle up your own air and let the air in the bottles cool to ambient, then use them in your car.
who syas you need a solinoid? yes you can use a restricter valve but why not have it manually controlled, that way it is when you want it to be.
CO2 is proven to work hella well on intercoolers, 50% tempature reduction, im not kidding. we tried it out on a turbo Vr4. w/o CO2 intake temp was 114 F. with CO2 intake temp was 61 F. when we installed and did a non running test ice crystals formed on the intercooler... the car was wrecked before we had a couple of dyno runs.
Old 12-09-2004, 09:23 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
releasing compressed oxygen into a warm engine bay is a good way to start a nice hot and uncontrollable fire.
Nitrous Oxide is better because if the intake picks some up thats good as opposed to picking up CO2 which would be bad.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 12-10-2004, 07:24 AM
Thanks a lot everybody! You're really unique!
I've a last question.
ShoulI I leave the gas is freed on intercooler or I must do a circuit closed so that cold only?
Do you understand?
Close circuit like a Refrigerator.
Thanks!
Old 12-11-2004, 12:21 PM
CBFryman's Avatar
Banned
just let if go free. we arent trying to refridgerate your intecooler here, just coll it down a it to improve its efficency for a while. plus if N2O or O2 inriched air is used there is a good chance come ill leak into your intake.
