Old 12-08-2004, 02:44 AM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
Question radar signs
ok why is it when ever i go buy a radar sign it always says im goin gf miles slower than what my speedometer says? so if that is my actual speed is that what the cops see when they hit me with radar/laser?
Old 12-08-2004, 11:20 AM
thecackster's Avatar
thecackster thecackster is offline
Send a message via MSN to thecackster
Re: radar signs
it could be your speedo is off.... or the radar is off... I know that cops use tuning forks to make sure that their radar is on... but if it's consistant... then my guess is it's your speedo.
97' Chevy Silverado
K/1500 Z71
350 Vortec
Flickr My Website
Old 12-08-2004, 12:51 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: radar signs
Our speedos are not as accurate as a speed detector. Figure out what your real speed is, higher or lower, and adjust driving past a cop as not to speed.
Old 12-08-2004, 04:40 PM
george536's Avatar
george536 george536 is offline
Re: radar signs
mine says im going 3mph faster than im really am.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 12-09-2004, 12:17 AM
Re: radar signs
WEll then it should keep you from gettn' so many "small" tickets haha
97' Chevy Silverado
K/1500 Z71
350 Vortec
Flickr My Website
Old 12-09-2004, 09:16 AM
GSTRacerNVUS GSTRacerNVUS is offline
Re: radar signs
I'm 5 over with 18's... Not sure if that has anything to do with it though.
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
Old 12-09-2004, 09:28 AM
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
Re: radar signs
tire size changes gear ratio, and throws off your speedo. I had a programer for my truck i had when i had 20s on it. my speedo was like all crazy before the programer.
95 GST
5 Speed
Cone Open airfilter
Custom 3" Turbo Intake
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 12-09-2004, 10:00 AM
Re: radar signs
Don't bigger wheels make the speedo slower or is it the other way around.
97 Eclipse GST MT
Old 12-09-2004, 02:27 PM
Re: radar signs
yeah but you are really going faster than what it says, my friend put bigger tires on his truck and he is going 8 miles faster than his speedometer reads
Old 12-09-2004, 03:32 PM
Re: radar signs
I would say you are correct; however, radar says its 5mph less than what I'm going.
97 Eclipse GST MT
Old 12-09-2004, 07:53 PM
Re: radar signs
Wierd
97' Chevy Silverado
K/1500 Z71
350 Vortec
Flickr My Website
Old 12-09-2004, 09:00 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: radar signs
wheel size doesnt matter. what matter is the tire size. i forget the formula but basicly you need to figure out the circumference of your tire and then there are sites that will tell you the speedo difference.
that said its probably not your tires making the speedometer inaccurate. its probably just that the stock speedo isnt very good
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
