Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 12-08-2004, 12:37 AM
KaMaKaZiPyRo KaMaKaZiPyRo is offline
Send a message via AIM to KaMaKaZiPyRo
Power To Weight Ratio
Can someone explain the whole power to weight ratio thing. I wanna compare cars but im not sure how, the only things ive heard of are that its the power or torque divided by the cars weight, but whats the number mean if your comparing it? Also I heard sumthin like a car with 250hp and 2000lbs, could keep up with or would be around the same as a car with 500hp and 4000lbs. Yes I know there are alot of facotrs like driving suspension, weather and all that but wats the basics, and how does rwd,fwd, and awd change things?
*Number Edit*
Currently trying to piece together a Turbo CrVtec bubble hatch, expecting sumthin like 500hp?!?!?!
Old 12-08-2004, 02:21 AM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
Re: Power To Weight Ratio
first off i assume that you meant 250 where you said 2500. anyways, it is generally so and so pounds per horsepower. like a 2000 pound car with 250 horsepower has 8 pounds per horsepower. a 500 horsepower car that weighs 4000 pounds also has 8 pounds per horsepower...
LS1 RX-7 Zoom Zoom
Old 12-08-2004, 11:19 AM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
That's the general idea. For example, a Lotus Elise, which has 190hp but weighs under 2000 pounds can keep up with and M3, which has 333hp but is much heavier.
Old 12-08-2004, 09:37 PM
d16civic d16civic is offline
the general idea is hp/weight.
fwd,rwd,awd in theory will differ at launch fwd will tend to spin tires because of the weight transfer from front to back,rwd will have an advantage in this case and awd should technically dominate but then you think,all that power is being distributed to all 4 wheels(awd)and that most likely has a negative effect,because you are distributing the same amount of hp to 4 wheels instead of 2.
dont quote me on this because there are instances where this "theory"might be proved wrong
Old 12-08-2004, 09:39 PM
i meant weight/hp
Old 12-09-2004, 12:31 AM
honda_luvr_2000 honda_luvr_2000 is offline
yeah that's exactly it, u all have it. guess we could kill this thread now. j/k
