Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 12-08-2004, 12:21 AM
mfayant mfayant is offline
mass air flow sensor replacement, does the...
Can anyone answer this one? mass air flow sensor replacement, can the connector be replaced instead of the whole sh-bang, isn't it the the connector relays the information back to the computer. If you looks at mass air sensor how can one tell the vacuum is not working or however it runs.
This way when i got to a autowrecking place I can grab the connector and not the whole system.
comments please,
m f
Old 12-16-2004, 03:20 PM
B33p3r B33p3r is offline
Re: mass air flow sensor replacement, does the...
The MAF is basically a hot wire. The air coming in flows across the wire. The air cools it to some degree. It's the temperature change that is converted into a voltage signal back to the PCM.
Old 12-16-2004, 03:29 PM
that's okay, I replaced the MAF with a used one, and am getting better mileage again.
m f
