Old 12-07-2004, 11:59 PM
MIGTPGUY MIGTPGUY is offline
Send a message via AIM to MIGTPGUY
CASE Learn Questions
Hi, im reading about that Intense PCM, wow, looks like Intense really has DHP by the ballz on this one. I have a question tho... i heard if you go to the dealer to get a CASE Learn you have to make sure they dont re-flash your PCM...Intense's website and other people have said that you have to be discrete about telling the dealer not to reflash./.... why is this... are you not suppose to have a aftermarket PCM>???? and how do you be descrete about it... can i not just say "yo, dont reflash my pcm"???? Someone, please elaborate on this for me....
Old 12-08-2004, 06:47 AM
stlwagon stlwagon is offline
Re: CASE Learn Questions
Generally it's because it could void any warranty on your vehicle. But in most of our cases, our warranties are long expired, so who cares! Anyone with a Tech II can perform the case learn.
However, since you're getting a 97 GTP, you don't need a case learn anyway. You just have to remove the knock sensor from the stock PCM and put it in the new one.
Old 12-08-2004, 02:30 PM
Yeah i juss read on that, that is so tight how it works out that i am getting a 97 GTP and only on those years you can juss switch that knock sensor.
Old 12-08-2004, 08:57 PM
SsHaDyGt SsHaDyGt is offline
i have a 98 gtp will i need a case learn and how DO you be discreate because i have a warrenty
1998 silver gtp, GM performance Handling kit ,cold air intake, KYB struts ,HD supercharger coupler ,Gatorback belts ,U bend delete ,NGK TR6 plugs ,DHP PCM, Electric exhaust cutout - SOLD
98 White GTP, N* TB, 3.0 MPS pulley, SLP headers, 1.9 Rockers, 105# springs, ZZP PCM, Flowmasters, GM performance Handling kit, FWI, GMPP springs, U bend delete, SSIC, Ported LIM, Autolite plugs, ported SC, 12" brake upgrade with slotted cross-drilled rotors,
Old 12-08-2004, 09:26 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Yes you need to do it. The only way to keep the warrenty is to keep stock PCM and install it any time you take it back for work.
Old 12-08-2004, 10:36 PM
so how can i go about getting the case learn done?
Old 12-08-2004, 11:03 PM
Well Cass had an idea of calling some body shops. A lot of GM get hit and have to be fix. They may do them.
I called the shop that works on my car, told them what I needed done. He told me that he couldn't do it, but said he would get back to me. He called snap-on. The next day he bought everything he needed to do it. GM dealers can but won't do it. If you go into their shops, most will reset your PCM to stock. Local shops have to be told not to touch, or most will mess it up. All I can tell you, if you take it in to GM, put the stock one back in.
