not this.. again..
ok, here we go.. under acceleration my car is sputtering.. again.. last time i replaced the O2 sensors, and plug wires.. not long ago, pry June or so, and im having the same problem.. would replacing the plugs and wires fix this.. or should i replace the sensors again..... im getting tired of the same shit happening over and over..
![]() "doing that is like trying to sell porn to a 6 year old..... It's just wrong" - hypsi87 LE123456712: i promise i will stop filling your email with my boobs Kieft125: lol.. good, its starting to get rediculous.. |
Re: not this.. again..
all that stuff should have held up longer than 6 months. may just need a bottle of fuel injector cleaner and replace your fuel filter
im hoping its nothing more than that.. because if it goes beyond there its getting too expensive for what i can afford at the time.. my budget's tighter than a.. well.. its just tight.. lol
i herd that, has the car been sitting any?
nope.. im not planning on storing it unless i have to.. and im ridin it out until the last possible second.. because i still have no insurance on the truck..
did the v6 models come with optispark? im not totally sure, but i didnt think they did... thought that was just for the Z28..
Im not sure about that one, I know my Z28 did that a while back after changing plugs and wires, turned out to be my OptiSpark.
its only under acceleration? could be fuel filter, fuel pump, injector problem. I would have it hooked up to a tech 2 and see if you can monitor the sensor inputs under acceleration and see visually what the problem is. Sounds like the mixture is definatly going off somehow either rich or lean.
Chevrolet Camaro - I enjoy beating the hell out of people http://www.automotiveforums.com/vbulletin/showthread.php?t=68052 |
its proelly ur cat, or some restriction in the fuel line... Hollow out your cat. I hade the EXACT same problem, Does your MPG suffer as well?
are your wires on the 02 sensors touching headers or a y-pipe? mine use and they would melt and back to buying more 02 sensors
well.. i know as much to say its not the cat..because i dont have one.. i checked the o2 sensors and they're not touching anything.. i already looked at those.. one of my plug wires was kindof resting on the intake.. and got melted just a tad.. i remember that happening before.. changed the wire.. no more problem.. so far..
fuel injector
same thing happened to my 94 Z a lil shake/hesitation when accelerating hard, i replaced the plug wires an fixed it but it showed up again later-some fuel injector cleaner got rid of it for good
Re: Re: not this.. again..
COMPLETELY removing the poti-crap sustem from the lt1! i am gettingthis kit as soon as i get the money. |
