Old 12-07-2004, 09:28 PM
Goatmann Goatmann is offline
Tranny Whine
I have an '01 GP with the 3.1. Bought it used with 57k and change on the odometer. It now has a little over 59k. At highway speeds 50 and above after getting the tranny hot there seems to be a whinning noise coming from around the transaxle area. While traveling at speed I shifted into neutral and revved the engine and the whine increased and decreased with the rev's. Does this sound like the tranny is shot 'cause if it is I got a 90 day warranty from the dealer and I'll need to have him make good on a new one if that's the case. I know some of you guys out there rebuild these things so let me know if you know.
Old 12-08-2004, 01:17 PM
Re: Tranny Whine
I guess no one out there knows anything about this, huh?
Old 12-08-2004, 04:56 PM
ericvrose ericvrose is offline
Well mine started whinning about a month ago after the dealer did a FLUSH! Whine when shifting from first to second and to third. Now it does it for a few seconds going from park to drive or reverse and all the time when driving. Getting worse and I'm taking it to the dealer next week. Still under warranty. It sounds to me like a bad bearing but I also see my MPG getting lower and lower so it may be slipping a bit. RPM's look a little high for corresponding speed.
Old 12-08-2004, 05:47 PM
bcreverend's Avatar
bcreverend bcreverend is offline
what about when you are just sitting in neutral and rev? are you sure its not the belts?
silver 99 grand prix gtp with Intense standard pcm, 3.4 intense modular pulley, oversized supercharger idler pulley, zzp underdrive water pulley, zzp overdrive alternator pulley, tps enhancer, open cone filter, thrasher shift kit, strut tower bar, eibach springs, autolite spark plugs, 180 degree t-stat, throttle body spacer, flowmaster catback w/U-bend delete, Rear O2 simulator, silvania headlights, xenon foglights, 40 cp reverse lights, and a custom 600 watt audio with cd changer.
Old 12-08-2004, 05:59 PM
Re: Tranny Whine
Not really. It seems to be more prevalent when the tranny is hot and traveling at highway speed. That's when I dropped it in neutral and revved it and was able to cause the whine to fluctuate. The whine diminishes below 50 and can't really be recreated when sitting in park and revving or stationary in neutral and revving.
Old 12-09-2004, 01:57 AM
fatalerror fatalerror is offline
My advice is take advantage of the warranty, trannies arent cheap.
Old 12-09-2004, 06:53 AM
nimmy_60504 nimmy_60504 is offline
Re: Tranny Whine
Hi I HAVE 2000 Grand PRIX
Iam having the same problem accept when it shifts from gear
to gear, it shifts hard. I also have a whining noise, gets worse
when I rev the engine. The car has 61,000 on it.
Does your car shift hard, if so let me know!!!!
If you have fround a solution also let me know!!!
[email protected] thank you.
Old 12-09-2004, 11:34 AM
Actually, mine is shifting OK. It feels normal in Perf shift mode and non. And it does whine in neutral now. When the problem first started it didnt. When I start in the morning it whines for about 5 seconds in park then goes away. Then putting in rev there is a louder whine and it calms down so I can barely here it until I start moving. Same in Drive. I'm taking it in next Tuesday unless it gives up before then. I'll post back the results.
Old 12-09-2004, 11:47 AM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
Re: Tranny Whine
i think it has something to do with the car having traction control- - i usually dont us it cause traction control is hard on the trans an hurts your gas milage a bit....
Old 12-09-2004, 12:47 PM
Thats interesting. I always thought TC took control of the the ABS system.
Old 12-09-2004, 02:48 PM
Re: Tranny Whine
I got your e-mail
TRAN WHINES/SHIFTS HARD
2000 GRAND PRIX SE
Im not sure what I should do!
I just bought the car 3 weeks ago,
used. I was informed at the time of
sale "that I had 90 day warranty"
on the drive train,so I guess its back
to the dealer.
I just wanted to see if anyone else
had a similar problem.
something to tell the dealer.
thank you J.T.
Old 12-09-2004, 09:44 PM
Picked up the SE from the dealer and was told that one of the techs there who is familiar with the Olds Alero said that this noise is normal. All I know is that it is now documented on my RO and if it gets worse it's going back. I think, though that if I can recreate the noise and I'm in the area I'll just stop by and have a tech take a ride. As you know it's sometimes hard to believe if they really put the proper time and effort into trying to recreate the exact symtoms.
Old 12-12-2004, 08:40 PM
Re: Tranny Whine
ya i am sure the noise is normal but i am pretty sure that it comes from the trans - i tell my girl not to use the TC unless its really bad outside an she is scared..lol - but ya it does make the trans work harder than it has to especially if u are in stop an go or u excellerate hard-
Old 12-24-2004, 05:53 AM
Shar0269 Shar0269 is offline
Exclamation Re: Tranny Whine
My transmission started doing a whinning noise about 6 months ago. I was driving along and the car felt like it dropped down gear on its own and I started experiencing a whistling whining noise. I thought it was the catalyic converter, I had the it changed and the noise was still there. I took it to the dealer and they thought it might have been trash in the catalyic that needed to be blown out. WELL IT WASN'T THAT! The noise got worse and worse and transmission went as I driving along on the highway, which could have been dangerous. That was on Tuesday (12/21) and I got it back Thursday (12/23) for $2500.00 (Merrry Christmas to me!).
Get it checked out ASAP!!!
Old 12-24-2004, 10:39 AM
WOW! You got it back in 2 days! Who did the work. Mine has been at the dealer for nearly 2 weeks! The first week it sat there with nothing done except they tell me its broke. GM warranty rep. has to decide which is cheaper, rebuilding or replacing. As of today I still dont know what the hell is going on with it. I hate the whole thing.
