Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 12-07-2004, 08:58 PM
drmattdogg drmattdogg is offline
Timing belt change.
well lately ive noticed my timing belt has been pretty squeaky. im just curious if thats a sign that it needs changed? i was just wondering how i should go about inspecting it? as to my knowledge, it hasnt been changed since i bought the car with 75k miles on it, its up to 118k now. also what kind of price range should i expect to have that done because this is not something id want to attempt myself. it seems a pretty labor intensive job and i dont have the tools for it really.
Old 12-10-2004, 10:01 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
zetec of duratec?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 12-14-2004, 12:26 PM
Re: Timing belt change.
its a 4 cylinder, i think zetec? if i remember ill recheck it
Old 12-14-2004, 07:07 PM
Re: Re: Timing belt change.
I would definetely get it changed just for preventive measure, as the belts can stretch over time. I certainly wouldnt recommend doing it yourself if you dont have the proper tools and a service manual.
"The CEG Nazi"
www.contour.org
Old 05-18-2006, 11:51 AM
xuto xuto is offline
At 75k you are getting pretty close to a timing belt change.However the squeaking that you here is not your timing belt because timing belts can't squeak, they have teeth like a gear. The squeaking noise you are hearing is coming from your serpentine belt. This should be replace and it is significantly less expensive.
