Old 12-07-2004, 07:22 PM
tonyfdny tonyfdny is offline
4x4 problems after truck fire
I’m new to this forum someone please help. "BlazerLt" thanks for your helpful tips Im hoping someone has experenced something like this before. My 95 blazer caught on fire due to a short in the power grid on the driver's side quarter panel. I rewired the engine harness and everything works except the 4H. when I start it the computer does the check sum. lights go on then off. the truck is in 2H, no lights are on in the switch panel. you can push the buttons all you want nothing happens. I put the truck in neutral and push 4H the lights flash 5 times and sometimes all the lights stay on and sometimes the all turn off the same thing happens when you push the 2H button. regardless the truck is still in 2H. Push 4Lo the truck goes into 4Lo the 4Lo light stays on everything works fine. Then push either 4H or 2H the lights flash 5 times and the truck is in 2H again. The only time I can get the panel to respond is when the truck is in neutral any other gear forget it even in park. this also works the same with the truck off, the keyed switch in the run position and in neutral. I’ve replaced all damaged parts except the 4 wheel drive control mod. and I have correctly replaced the vacuum hoses. some one please help me.....
Old 12-07-2004, 11:21 PM
cubanlorenzo cubanlorenzo is offline
Send a message via AIM to cubanlorenzo
Re: 4x4 problems after truck fire
i had some what of the same problem, no fire haha. put the 4X4 switch. same exact thing happened to mine. i woul dhave to put it in neutral to have anything happen. i pulled the negative bettery terminal for 10 mins and everything is working again. 100%. hope this helps
Old 12-08-2004, 03:06 AM
Re: Re: 4x4 problems after truck fire
thanks for responding. i tried removing the battery for a while and that didnt work. do you know what the 5 flashes mean? ive got a few responces from a few people and they are telling me to check the vacuum switch under the battery. I have yet to check that. also I have been thinking about replacing the 4x4 control mod under the dash. any other ideas. can the computer be tested? any idea onwhat i have to remove to get to the computer?
Old 12-08-2004, 11:57 AM
also check the vaccumn on the transfer case.
