Old 12-07-2004, 08:21 PM
Dagger99 Dagger99 is offline
PA coil replacement.
Will the coils of a 1988 Olds Regency 3.8 work with my 93 PA 3.8. I dont need to replace the whole power pack just the coils.
Old 12-08-2004, 04:31 PM
parkavenuechrome parkavenuechrome is offline
if it is a 3800 motor then yes it should work. Coils generally are all the same. Shape and Size vary. I use a 85 mustang GT 5.0L on my Saab 900 16v. There all the same, just size and style my friend.
Old 12-09-2004, 09:21 AM
pirho451 pirho451 is offline
I would say no. The AC Delco part number for the '88 coil pack is D552. The part number for the '93 is D555. The big thing is that it appears that the '88 part contains all 3 coils, instead of just one like the '93 is.
Old 12-09-2004, 02:04 PM
If They fit on the tower as a whole and hook up, then they will work just fine, part number different or not. If yours is 3 coils seperatly then your kinda in a jam there.. unless you get all 3 to fit then you will be ok.. which style to you have?
Old 12-10-2004, 03:16 PM
Yeah, that's what I was saying. According to everything I found, the coils for the '88 engine were all one unit. Of course, GM is known for changing things mid-year and saying that each engine still used the same parts.
Old 12-11-2004, 12:43 AM
Re: PA coil replacement.
Im not sure which one I have. I will have to check it out. Thanx!
Old 12-13-2004, 03:16 PM
My 91 is all one unit as well, but all the aftermarkets are seperate.. which is better anyways I think.
Old 12-15-2004, 03:02 PM
deadring deadring is offline
strange, i got a 92 and i got 3 seperate coils.
Deadring
Old 12-15-2004, 07:12 PM
I checked the PA and they are seperate coils. The Regency has all 3 molded together. I guess I will have to find them somewhere else as I dont think the they will hook up into the conection.
Old 12-16-2004, 04:05 PM
Re: Re: PA coil replacement.
The 1991 Pa comes with all 3 molded.. I bet they will work just fine. they just look different but bold up the same.. Give it a shot.
