Go Back   Automotive Forums Car Chat > Coffee Break (Off-Topic) > Stress Release
Stress Release Warning: Don't get offended by what's in here.
Old 12-07-2004, 06:49 PM
Cait Sith Cat Cait Sith Cat is offline
Send a message via AIM to Cait Sith Cat
WHY are heater cores so ard to access?
It's literally at the core of the car.. it shouldn't be so deep in if it's going to break as much as they do. It's such trouble...
Old 12-07-2004, 07:20 PM
2strokebloke's Avatar
2strokebloke 2strokebloke is offline
In Stereo where available
Re: WHY are heater cores so ard to access?
It's because heater cores are stupid. Good cars are air cooled.
I've never had a heater core "break" - what kind of a car are you fixing?
Support America's dependence on foreign oil - drive an SUV!
"At Ford, job number one is quality. Job number two is making your car explode." - Norm McDonald.
If you find my signature offensive - feel free to get a sense of humor.
Old 12-07-2004, 07:53 PM
my 96 Crown Vic P71 has a leaky heater core. to get it out you have to take the whole dash out.. it's hell in July. I couldn't get to it, I gave up.
Old 12-07-2004, 08:47 PM
ghostguy6's Avatar
ghostguy6 ghostguy6 is offline
Send a message via AIM to ghostguy6 Send a message via MSN to ghostguy6 Send a message via Yahoo to ghostguy6
did you check the firewall from the engine compartment?
Want to be a mod? Join up at www.mypicgallery.com and PM me.
Old 12-07-2004, 08:57 PM
aloharocky aloharocky is offline
Banned
Have you thought about cutting an access panel so that you can get in from the other side? Sometimes that works, and sometimes it won't. I cut access holes wherever I need to, and they are easy to hide when the job is done. The Crown Vic is eight years old already, so it's not likely to de-value it even if it's visible.
Old 12-08-2004, 07:21 AM
Jimmiz71's Avatar
Jimmiz71 Jimmiz71 is offline
It Must be a Ford thing, My dads Heater Core went in his old Crown victoria, and we had to remove the Dashboard, same in the Mustangs of the early 90's. Its a bitch... I haven't had to replace one on any of my chevy's yet, but I dont think its too easy a job in any car.
-Jimmy
~99' Silverado z71 LS 5.3~
Alpine CDA-9830 Head Unit
2-JLW12 Subs
Infinity Surrounds
Too Many Extras
04' Yamaha YZF R6 Super Sport~
Liquid Silver with Black Ghost flames
K&N Filter, Fender Delete Kit
Aftermarket Mirror Shield
Devil Carbon Fiber High Mount Pipe
Power Commander III
02' Subaru WRX Turbo Sport Wagon
Eibach Springs, Short Throw Shifter
17" Versus Campionato Wheels Wrapped in Pirrelli tires
Old 12-08-2004, 08:34 AM
ghostguy6's Avatar
Re: Re: WHY are heater cores so ard to access?
-Jimmy
Its easy on my car:
#1 take off air cleaner
#2 remove 4 self tapping screws
#3 remove cover plate
#4 pull out heater core and losen 2 hose clamps and remove hoses
#5 install new heater core and reassemble
#6 top off engine coolant to replace any coolant that was lost in the process
For me it was only difficut because my fingers were numb from working outside at -40 and i couldnt get a grip on the hoses to pull then off
Old 12-08-2004, 09:51 AM
Jimmiz71's Avatar
I stand corrected! But I feel your pain.. Last Feb. my friend stopped over after attempting to change his fuel filter on his 98' taurus, he somehow managed to damage the fitting. nothing like fuel leaking on your hands when its below 0.
On The 90' Mustang GT we replaced the heater core during this past summer, the entire dash had to come off, and because it was leaking there was antifreeze in the heat ducts. when we pulled the dash off, antifreeze spilled out onto the floor and the vents had to be cleaned. AlohaRocky has the right idea, we used a zip tool to cut a removable access panel in the firewall incase it needs replacing again.. It would have been nice if we thought about that before taking the dash out.. but oh well..
-Jimmy
2-JLW12 Subs
Infinity Surrounds
Too Many Extras
Power Commander III
Old 12-08-2004, 11:14 AM
Banned
I stand corrected! But I feel your pain.. Last Feb. my friend stopped over after attempting to change his fuel filter on his 98' taurus, he somehow managed to damage the fitting. nothing like fuel leaking on your hands when its below 0. -Jimmy
The Taurus is simply a mechanic's nightmare. Every part on it was engineered to rip the skin off a mechanic's hands, and be accessible only after removing half the engine. All engineers involved with that design should be executed, and future designs be approved by the people that have to work on them. Try changing a front engine mount on one, or heaven forbid, the power-steering hose. Someone even came up with a quick-fix part for that one, because it's almost impossible to do otherwise. I had a 90, and am so happy it ended my misery by catching fire. I didn't even try to put it out.
Old 12-08-2004, 11:45 AM
ghostguy6's Avatar
-Jimmy
Theres a special tool on the market for doing that, Ford In there infinate wisdom desided that it would be nice to redesign the fittings to use metal clips so you didnt have to worry about breaking the plasic ones , unfortunaly they look very similar to the older style clips used by GM What you need to use was one of these, the red one:
My guess is you tried to just pull the fitting out and you bent the metal retaining tabs back and had to replace the whole section of fuel line. Just once I would like to meet an engineer from ford
Trust me I know your pain I cracked the carb casing last time I changed my fuel filter, unfortunatly I thought it could wait until the spring but no, It had to go on a -25*C day and needed to be changed. There was a fucking air bubble in the casting so when i tightened the filter housing it cracked, cost me $720 for a new carb
Old 12-08-2004, 08:12 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
haha...had to do that in my thunderbird. I think it would be easier in a crown vic since their isnt a center console in the way.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 12-08-2004, 08:29 PM
mjgjr72 mjgjr72 is offline
because the guys that design them don't have to fix them
worst ones i have done are most of the fords truck and cars
some of the chevy blazers
dodge durangos
jeep chereekes
and others i can't or just don't want to remember
have lost lots of skin
Click To See My Ride 2000 Chevy Silverado LT Z71 K1500 ecsb, 6" suspention lift, 4.56 gaers, 315/75r16 bfg mt, radix supercharger, gibson headers and cat back, trasgo shift kit, aluminum servos, nelson tune
Old 12-17-2004, 01:53 AM
runningmole runningmole is offline
Send a message via AIM to runningmole
I've had to do the core in my Mustang twice. 1st time was tough. We didn't pull the dash all the way off. 2nd time, we dropped the steering column, and pulled the dash. Made it so much easier. In our old family car, 89 Buick Century, all you have to do is remove the glove box. My brother had the whole thing done in about 90 minutes. Our old 77 Camaro was pretty easy. It didn't have factory AC, so you could access the box for the heater core from under the hood.
1993 Mustang GT
Blue/Titanium 2tone, 5spd, 3.55s, JBA ceramic shorties, catted H-pipe, dumped Magnaflows, MSD goodies, FMS alum rad, Pro50, balanced/blueprinted forged 327 stroker (8.2 compression), AFR 185s, Performer RPM, 70mm TB, FTI custom cam, SFC, In-floor Subframes, Maximum Motorsports Torque Arm and Panhard Bar, H&R Springs, Bilsteins, MM CC plates, 5 Lug Conversion w/ Silver Bullitts. Full accessories including smog legal. 310rwhp 351rwtq Dyno Dynamics Dyno. Soon to be supercharged
Old 12-17-2004, 10:33 AM
WickedNYCowboy's Avatar
WickedNYCowboy WickedNYCowboy is offline
Send a message via AIM to WickedNYCowboy Send a message via Yahoo to WickedNYCowboy
You need to pull half the dash and engine compartment apart to get to my heater core. I REALLY hope it doesn't go out. I do know the F-350 Powerstrokes are a BITCH to do a heater core on.
Evan
Support your local volunteer fire department
My Rides:
2003 Ford F-350 Long Horn Hauler
Others:
1999 Toyota Camry LE V6-Dad
2004 Chevy Tahoe Z71-Sister
2004 Toyota Camry LE V6-Mom
Old 12-17-2004, 04:45 PM
ghostguy6's Avatar
Try doing the heater core on a mazda...........................
