Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-07-2004, 06:17 PM
sdogg518 sdogg518 is offline
Send a message via AIM to sdogg518
gauge problem
hey guys need some help. im lookin to buy this 1995 eclipse but the speedometer and the odometer dont work. does anyone know how to fix this problem or know of any instructions or what not to how to go about fixing this problem?
thanks a bunch,
scott
get in, sit down, shut the hell up, buckle ur fat ass up, and HOLD ON!!! ...
Old 12-07-2004, 08:45 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: gauge problem
set it on fire, call you insurance company, they'll buy you a car with one that works!
DSM geek
Old 12-07-2004, 10:14 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: gauge problem
there is a fuse for the guages. im not sure which it is on a 2g but that should fix it.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-08-2004, 07:25 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Re: gauge problem
This blew my mind when I figured it out......you can remove a fuse and the odometer stops working.....
If I remember correctly you also loose your speedo, tach, power windows and locks.........
DAMNIT
Oh well.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 12-08-2004, 01:43 PM
Re: gauge problem
thanks a lot for ur help guys
Old 12-08-2004, 02:33 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: Re: Re: gauge problem
So get a big ricer speedo and tach and take that fuse out
For Sale 98 Eclipse GS, 5 spd
Old 12-29-2004, 01:20 PM
lv_sinnerz lv_sinnerz is offline
Forgive the dumbass question, but I'm assuming that is the same thing with a 90 eclipse, right? Where the fuse is just blown and needs replacement?
~J.
"ONLY YOU can prevent the spread of stupidity. USE A CONDOM!!!"
Old 12-29-2004, 03:29 PM
GSTRacerNVUS GSTRacerNVUS is offline
Re: gauge problem
yes, as long as its the same situation.
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
Old 12-29-2004, 04:09 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
DAMNIT
Oh well.
Or you can just go under the hood and unplug the speed sensor. Then all it affects is the speedo and odometer! Then if you need to know what speed you are going pick a certain RPM to remember certain speeds. I do this when I take long trips, like 4300rpms in 5th gear = 100mph!
Old 12-29-2004, 04:29 PM
Re: Re: Re: Re: gauge problem
Yeah, the thing is I want to AVOID being chased by a fleet of armed police officers with itchy trigger fingers!
~J.
Old 12-30-2004, 08:22 AM
I have a logger that shows vehicle speed as seen by the ECU. Will unplugging the speed sensor effect the logger??
1997 Spyder GS-T
5-Speed
Old 12-30-2004, 09:26 AM
ashah000's Avatar
Re: Re: Re: Re: Re: gauge problem
That better work, cause my logger is on the way.
Old 01-01-2005, 10:35 PM
Re: gauge problem
unplugging the speed sensor will make it so the logger doesnt know how fast you are going since the logger uses the same sensors as the ecu.
-1stGenRocks-
Old 01-03-2005, 01:52 AM
Re: gauge problem
Err.... I tried checkin the fuses, and they seemed alright, but I saw none that were of just the speedometer guage. Unless it was just the guages itself, and in that case, if that fuse was bad, wouldn't none of the guages work? Because my RPM guage works fine, and so does gas, warning lights, etc, just not odometer and speedometer.
~J.
Old 01-12-2005, 02:39 AM
Re: gauge problem
Stupid question time again.... The speedometer cable, where the hell is it connected? Is it connected from the engine side of the firewall or from the instrument cluster? I took the dash apart and we could NOT get that cable to come loose from the dash side. It just would not budge!
~J.
