Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-07-2004, 03:54 PM
donlegg donlegg is offline
Programming keyless entry fob
How do I program a keyless entry fob for my 1999 Suburban?
Old 12-08-2004, 07:13 PM
fort4short fort4short is offline
Re: Programming keyless entry fob
Who is the manufactor of your keyless entry?
Old 01-09-2005, 10:57 AM
Logixman Logixman is offline
Hi,
Here is a program I found that works on my 2000 suburban.
1. Get in you car (have all the remotes that you want programmed with you at this time, even if you have one that works already because this procedure will reset that one as well). close the door
2 While holding down the unlock button on the driver side door:
A. put the key in the ignition and turn to the on position then to the off position then again to the on postion then to the off position (don't be too slow when you do this, probably all four motions within 5 seconds). do not remove key from ignition yet.
B. Immediatley release the unlock button. You should hear the lock system cycle within a few seconds. This indicates that you are in program mode. If you don't hear the locks cycle go back to step 2
C.Take your first remote and hold the lock and unlock buttons at the same time for about 15-20 seconds (most instructions say seven seconds) until you hear the locks cycle. Your first remote is now programmed.
D. Repeat step C for all other remotes at this time
3. Once you have programmed all your remotes turn the ignition key to the on position, this exits programming mode.
Old 01-11-2005, 02:36 PM
Crossbard Crossbard is offline
Will this procedure work for a 1998 Suburban????
Old 01-11-2005, 03:10 PM
No, I tried it myself.
The 98's have a different looking remote so I'm guessing that it has some type of different procedure.
HELP GREATLY APPRECIATED!!!!!!!!!!!
Old 01-11-2005, 03:26 PM
Found instructions for my 98 in the Tahoe section.
Totally painless and took all of 30 seconds to do two remotes.
What a wonderful site!!!!!!!!!!!
Yet another painful trip to the dealer has been prevented.
Old 01-27-2005, 09:07 PM
perrys24 perrys24 is offline
Did it work? this didn't work for my 99 burb...
Old 02-14-2005, 12:25 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
99-01:
Transmitter Programming Base Model:
If they key is in the ON position during the programming procedure, the horn chirp will be disabled, if the key is in the OFF position, the horn chirp will be enabled. The horn will chirp when the lock button is pressed two times.
When reprogramming the remote control door lock reciever, All transmitters must be programmed at this time in order for the transmitters to operate the vehicle. Transmitters not programed at this time will not work and the procedure will have to be redone with all the transmitters.
1. Ground pin 4 to pin 8 of the data link connector (DLC). The receiver will respond by locking and unlocking the doors, and activating the liftgate window release (if equipped) within 2 seconds.
2. Press and hold the LOCK and UNLOCK buttons simultaneously on the first transmitter to be programmed until the locks cycle (approximately 10 seconds).
3. Repeat step 2 for up to four total transmitters to be programmed (if available). The receiver will respond by locking and unlocking the doors and activating the liftgate window release (if equipped) within 2 seconds.
4. Remove the ground applied to the DLC.
5. Lock and unlock the doors in order to verify the transmitter operation.
6. Activate the rear window release in order to verify the transmitter operation.
Method for Higher End models:
Have each of the transmitters that you intend to program ready. This vehicle will allow you to program a maximum of four transmitters programmed at one time.
Turn the ignition to the RUN position, then back to the OFF position. This will disarm the theft-deterrent system.
Remove the RADIO fuse (Fuse 17).
Turn the ignition from the OFF position to the RUN position three times quickly, within five seconds. The vehicle will respond by locking the doors, unlocking the driver's doors and releasing the tailgate or panel doors. The transmitter is now ready to match to the vehicle.
Press and hold the LOCK (1) and UNLOCK (2) buttons on the first transmitter for 15 seconds. The vehicle will respond as in step 3.
Repeat step 4 for the remaining transmitters.
Replace the RADIO fuse.
Check that all transmitters work by pressing their buttons.
Old 06-13-2005, 02:00 PM
20sTahoe 20sTahoe is offline
I have a 2000 Z71 Tahoe OLD BODY style. My remote part is 16245100-29. Do I need to use the 4/8 pin ground method or the high end method of removing radio fuse? Thanks for your time.
Old 12-07-2005, 10:48 AM
eriojas eriojas is offline
Re: Re: Programming keyless entry fob
2002 suburban changed battery on the remote control and it doesnt work, worked perfectly until one day it stopped working, is there anything i have to do because the battery change?
thanks
Old 12-14-2005, 11:02 PM
Onblsht's Avatar
Authorized Vendor
If you just changed the battery and it stopped working...
After you put a new battery in the remote, press and hold LOCK and UNLOCK on the remote for 7 seconds next to the vehicle to re-synchronize the remote with the receiver.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
