Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-07-2004, 03:09 PM
JenniK JenniK is offline
Send a message via Yahoo to JenniK
jeep wont start
having problems with spark and fuel! I thought the fuel pump was the problem but it does't have spark either. was told it might be Asd but can't get it to disarm. olso the fuel gauge is the only thing that doesn't work. could be maybe ecm? please help???
Old 12-07-2004, 03:28 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: jeep wont start
replace the CrankShaft Position Sensor.
you will also notice when trying to start that the CHECK ENGINE light doesn't come on - this is a sign of the CPS going bad.
Old 12-07-2004, 04:28 PM
Dale Aeppli Dale Aeppli is offline
Re: jeep wont start
Need year make model and engine. dale
Old 12-07-2004, 04:37 PM
Make, model, engine
It's a 1999 Jeep Grand Cherokee Laredo, 4.0l 6cyl.
Jenni
Old 12-07-2004, 06:10 PM
Re: Make, model, engine
Jenni
Like ask on other post does the check light come on when you turn key on? When you say you can't get it to disarm. Do you mean the alarm system. dale [email protected]
Old 12-07-2004, 07:21 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: jeep wont start
It's the CPS. Just had one in the shop the other week with the same symptoms. Swapped it out and all was fine.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 02-08-2005, 03:25 PM
itsk80 itsk80 is offline
Re: jeep wont start
I'd have to say ECM. Mine's being replaced as we speak. They thought it was the crank shaft position sensor, but it ended up not being that. I have a 2001 Grand Cherokee. Just all of a sudden wouldn't start when I came out of the gas station the other day.
Old 02-25-2005, 12:26 AM
norske norske is offline
Re: jeep wont start
where is the crankshaft position sensor located on a 93 jgc?
Old 02-25-2005, 03:40 AM
Re: jeep wont start
what engine?
4.0L - it is on the driverside of the transmission bellhousing.
5.2L - it is on the Passengerside of the engine block, behind the right exhaust manifold. - Easier to get to is you remove the exhaust heat shield and exhaust manifold on the passengerside.
