Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 12-07-2004, 12:22 PM
mikester_91 mikester_91 is offline
Rev ups, and drops. Please Help!!
Ok, after my car(92 honda prelude si 130,000 miles) is warm (driving about 10-15 minutes). When i come to a stoplight and push the clutch in or put it in neutral, the engine will rev up a bit and drop quickly back to idle, and do this about 10 times and quit. It doesn't just gradually go back down to idle either, it sounds like it's gonna die...like drops really fast. I have had the catalytic converter cut out with a 2.5 inch pipe going from the exhaust manifold back. could this be a messed up o2 sensor? Map sensor?Loose vacuum hose? EGR valve? Please help, no check engine light, however when i turn the ignition on, that light doesn't come on anyways so i don't think it works. Thanks.
Old 12-07-2004, 01:17 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Rev ups, and drops. Please Help!!
The first thing you need to do is get the check engine light working again. Your problem sound like the IACV (intake air control valve) some people refer to it as the fast idle thermo valve. It does the same thing as a fast idle thermo valve. Get the light working then see if you have tripped any CEL's.
Old 12-08-2004, 08:36 AM
Do you know how i'd get the check engine light workin again? Bulb or fuse or relay?
Old 12-08-2004, 11:18 AM
Lychus Lychus is offline
i actually have a similiar problem. I got a 95 GSR and the revs jump from 1 to 2 while idle. But it doesnt go away. it just does it all day long and also my check engine light comes on.
Old 12-08-2004, 03:08 PM
whtteg's Avatar
Re: Re: Rev ups, and drops. Please Help!!
I would start by checking the bulb. If the other lights light up then it would not be a fuse. Check the bulb and maybe even replace it, they are cheap.
You need to pull the codes form the ecu. To do this you will need a paper clip. Look under the dash on the kick panel on the passenger side, you will see two harness' plugged into a Green (i think it is green or blue can't remember) rubber thing. Take the connector out that has only 2 wires, you will want to bend the paper clip so that you can connect the two wires in the connector with it. Then turn your ignition switch to "ON" not "start". Then you will see the check engine light start to blink, you need to count these blinks. Now you will have short blinks and long blinks. The short blinks have a value of 1 and the long blinks have a value of 10 so if you have 1 loing blink and 4 short blinks then you have a code 14 which is IACV. Try it and post back if you have any questions.
Old 12-08-2004, 05:51 PM
Prelude707 Prelude707 is offline
Send a message via AIM to Prelude707
That might not be the problem. I'm experincing the same exact thing (randomly revs up to 1300 and then down to 700 after a while at normal temp) and I've tried the fix. It didn't do squat. I even went as far as to make a gasket to seal off the IACV valve from the TB completely. Still didn't help.
I've checked my temp sensors thinking that might be the problem, but no luck. I've tried several other things with no luck. I've got no CEL to go on either. And Honda refuses to check my car out because it's "too heavily modified" So I'm shit out of luck. It seemed to start right after I installed my nitrous, VAFC, and hi flow fuel filter.
Funny thing is it'll stop when it wants to. Once I shut off my headlights and it stopped
2000 Honda Prelude
Mod list-
AEM CAI, AEM underdrive pullies, AEM FPR w/fuel rail, AEM brake pads, Apex'i N1 catback exhaust, Random Tech Hi-flow cat, Autometer fuel pressure & A/F ratio gauges, Apex'i VAFC(dyno tuned), ACT Xtreme pressure plate w/street disc and streetlite flywheel, Zex wet shot w/dual bottles and purge, Neuspeed front strut bar, VIS EVO CF hood, Honda Access door sills, NX bottle warmers, Lean Racing short shifter
Soon to come-
17" wheels, ES motor mount inserts
Old 12-08-2004, 08:30 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
It is the IAC valve. All honda's and acura's have had a bad history with them. If you run even slightly low on coolant, the IAC valve will overheat and begin to do exacly what you described. I replaed mine and made sure the coolant was running through it and haven't had a problem since. Sometimes, and this is rare, but you can take it off and clean it out with some carb cleaner and then spray it with wd-40 and it will fix the problem....i haven't personally seen this work on a honda, but it does work on a GM.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 12-08-2004, 09:45 PM
LILT23 LILT23 is offline
take the fast idle valve off and clean it real good inside and outside and put back together and put back on the car should work fine after that .. oh yea when you open it see if the plastic part is screw down if not there is your problem but still clean it... it is right of the ECU !
Old 12-09-2004, 09:10 AM
I would just get a new one but i don't feel like spending 300 for one at a honda dealer. As for the check engine light, when i have the ignition turned on, the low fuel light and the seatbelt light don't come on either. I would replace the bulb but i heard taking the dash out is a HUGE project, and i'd rather hope it was a fuse and try to replace that since there's a few out.
Old 12-09-2004, 09:19 AM
whtteg's Avatar
Replace any and all fuses that are missing then reset the ECU and try again. C'MON guy you are missing fuses and wonder why something is wrong?
Old 12-09-2004, 11:43 AM
No dude, not a few fuses out, a few bulbs out. the fuses under my dash all appear to be fine.
Old 12-09-2004, 12:14 PM
whtteg's Avatar
..... I would replace the bulb but i heard taking the dash out is a HUGE project, and i'd rather hope it was a fuse and try to replace that since there's a few out.
Sorry guy the way it is worded makes it sound like you were taking aboiut fuses. Anywho.
You are saying that there are a few bulbs out? Like out of the dash or burned out? Either way i would replace them still, it will be hard to find the problem if the MIL does not work.
Old 12-09-2004, 01:46 PM
It could be a relay in the underdash relay box also.....but i dunno how to get to those.
Old 12-09-2004, 01:55 PM
r1000000000 r1000000000 is offline
i'd say hook up some NOS to it, Blow it up (KaboooooooooMMMM!), then put in a new B series...hahaha.
Old 12-10-2004, 10:00 AM
StrokedLSCivic StrokedLSCivic is offline
you boys need to get on ebay and find a GOOD used TPS(throttle position sensor) and replace with olddrilling required) to fit fluctuating idle!!!
