Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Performance
Performance Anything you ever wanted to know about boosting the performance of your Cavalier.
Old 12-07-2004, 12:11 PM
Sunbird_Owner Sunbird_Owner is offline
Performance tips
Alright *I am new to this forum but really enjoying the information* Anyways I need some tips from some people.
I have a 94 Pontiac Sunbird LE 2.0l 5 speed. The only performance peice I installed so far is a K&N airfilter. Any ideas of what to go to next. I am thinking maybe a Superchip. Jet seems like a good bet than some nicer plugs and than injectors.
Input would be greatly appreciated.
Thanks .
Old 12-09-2004, 12:46 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: Performance tips
Thanks .
Drop in K&N filters are ok, i would get an actual intake, i think that would make you happier. Those Jet chips are pieces of shit and do not work worth a damn. Intake, New intake manifold that has been port and polished, New header, upgraded ignition ( i.e plugs, wires, coil packs) high flow cat, stiffer engine mounts, lightened pullys, new exhaust muffler.. those are just a few to start that will burn a hole in your pocket.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 12-09-2004, 12:58 PM
KustmAce's Avatar
KustmAce KustmAce is offline
Grande Boleros de Fuego
Instead of just the cat and muffler, just get a new exhaust system, 2.25" header back.
MAKE ART, NOT WAR
Old 12-09-2004, 01:00 PM
Thanks for that info.
It is not illigal out here to not have a Cat. Would you sudjest just taking it out and putting a pipe there. It is just bolted in with clamps so I should be able to just clamp in some piping there.
For an intake I have been looking at the K&N ones but I got a question. I am the type that likes to do alot of the work himself. I was looking at my car the other day and noticed the pipe for my intake goes straight down and backwards beside the fender wall and behind the Rad... if I were to take some more tubing and run it, and cut a whole in my front air damn, through there would that increase airflow by much or just add to much tubing? It would kind of make it like a home made Ram Air cause the faster I go the more air it forces through the hose.
So whats wrong with the Jet chips? I have read up on them and also somehting called the G box. They have numbers but who knows where they got those from and what else they had to do.
So new ignition would add alot I know... but what brand is a good brand to go for? Any sudjestions on this would be helpful
And lastely I have been looking at some plugs and have seen some tripple pronged ones that are supposed to increase your throttle response.... is this true or false. They are 17 bucks CDN for 2 of them so I wanna know before I put the money into them *Full time student and part time pizza boy that is alot... got rent to pay too *
Anyways thanks.
Old 12-10-2004, 10:25 AM
hellraiser319's Avatar
hellraiser319 hellraiser319 is offline
Registered User
air flow should be your first concern. getting the air in the engine and out the engine is most important. if intake is restrictive, engine has to work to pull air in. if exhaust is restrictive, engine has to work to push air out. work on intake and exhaust more before wasting money on worthless chips. ram air would be a good idea for intake and id get all the curves out of the exhaust and make it straight as possible with a high flow muffler on end of it. chances are you have OBD I on there, and burning your own chip would be alot better than buying one, since you can tune car to what you need and have set up on drivetrain. only problem is finding someone with the equip. spark plugs are spark plugs. if your gonna waste money put $8 and some tax into bosch platinums and thats it. other ones dont do crap, esp the splitfires. with the bosch platinums ur getting a long lasting plug while saving money.
Old 12-10-2004, 10:39 AM
Lifted GMT-360!
Re: Re: Performance tips
I have heard bad things about bosch at times.. If you really want to blow 8 bucks a plug.... NGK iridium plugs are the way. Or... NGK TR-6, but you don't really have a use for colder plugs..
Old 12-10-2004, 11:03 AM
Registered User
by $8 i meant for the whole set, $2 each. i got them in my camaros and had no problems with them and the older camaro has like 50k on them i believe. they kick ass in mine now, its just a shame i blew a connecting rod.
Old 12-11-2004, 03:51 PM
Thanks guys this Forum rocks. So much information. I love this Sunbird already so I am not scared to put my money into it. I used to drive a 91 topaz so I guess any car is a step up lol.
Old 01-05-2005, 12:24 AM
noshun's Avatar
noshun noshun is offline
PCM flasher units are the way to go. You can choose your own programme and you can redo it after it resets itself for many reasons. You can also alter it with extra mods. You can do it from a palm pilot of laptop or the Superchips unit is a good one and I'm not talking send the ECU off for a chip to be soldered in the unit that you hold and play with. Remerber to save the stock settings though!!!!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 06-26-2006, 08:23 PM
decyphex decyphex is offline
Send a message via AIM to decyphex Send a message via MSN to decyphex Send a message via Yahoo to decyphex
where can you find a header for the 2.0 sunbird?
Anyone know where I can get a performance cam for it too?
A cam is also the way to go, Sunbird_Owner. Port and polish is also a good idea on this motor. I am going to be doing these mods to mine shortly.
Just make sure you do what was mentioned above and do a better intake and exhaust. I have a hollowed cat with a pipe through it (looks like it's still there ) and a high-flow muffler. Looking for a header...
Click the sig.
Old 06-26-2006, 08:26 PM
Those are some pics of the intake I have. Sorry about the low lighting but you should be able to get the drift on the all PVC one. You dont actually need metal for an intake, you can use plastic piping found at any home improvement store. It's easier to cut too.
The pic that has the stock intake tubing still on it is the old way I had it setup.
The pic showing the mount is where I custom mounted it to one of the engine mount bolts. (Does not mess with the integrity of the engine mount)
Click the sig.
Old 06-26-2006, 08:54 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
this thread is from a year and a half ago, i doubt they are still looking for the info, its good that you're searching through posts, but check the date before you reply to someone
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 06-26-2006, 09:03 PM
oops, sorry. I have a bad habit of doing that.
Click the sig.
Old 01-07-2007, 08:40 PM
Vejita88's Avatar
Vejita88 Vejita88 is offline
Camaro Lover
Send a message via Yahoo to Vejita88
I dont really like Bosch Platniums, i seem to have good luck with NGK V-Power or Platniums, but tht's just my opinion.
