Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-07-2004, 11:41 AM
drdrew33 drdrew33 is offline
99 rodeo 4wd question
first winter with 99 rodeo, and I notice with 4wd engaged, wheels spins while in tight turns? Is this normal or cv joints needed?
Old 12-07-2004, 12:26 PM
rodeo02 rodeo02 is offline
Perfectly normal for the part-time 4x4 setup these trucks have. Each axle takes 50% of the power in 4x4 mode & all 4 wheels try to spin at the same speed, so you will get some binding & wheel spin on tight turns. Try not to do tight turns on pavement in 4x4 mode. It puts a tremendous load on the drivetrain components.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 12-07-2004, 03:51 PM
Dober89 Dober89 is offline
Re: 99 rodeo 4wd question
on dry pavement right?
Old 12-12-2004, 05:13 AM
Letsrodeo's Avatar
Letsrodeo Letsrodeo is offline
That's right.
On dirt, mud, gravel, snow, ice, etc, there's enough wheel slip you won't put your drive train in a bind.
I've used mine in 4WD mode during heavy rains at highway speeds, but there were no sharp turns.
If you want something done right do it yourself two or three times!
1999 Isuzu Rodeo LS 4X4
American Eagle Series 149, 16X8
Toyo Open Country LT265/75R16
Rancho 9000
3" CP Lift, 3" PA Body Lift
Manual Locking Hubs, SuperWinch
Optima Yellow Top Battery
Custom Sound System
Shrockworks Rocksliders
Letsrodeo
