Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-07-2004, 11:15 AM
Skavball24 Skavball24 is offline
Brake issues
Brakes and rotors were change at 96k.....im now at 160k....should i need new brake pads???? anything else??? (assuming the car is taken care of properly)
Old 12-07-2004, 11:57 AM
Traktor Traktor is offline
Depends on how and where you drive. You likely won't have to mess with the rears, but 70K on a jeep driven off-road or regularly in the mountains (or towing a trailer) would be alot. If you're a light-foot and spend alot of time on the highway then you might be fine. You can remove a wheel and look at the pad to see how much material is left. If it's around 1/8" inch or less, then you should replace them (so that the rivets don't wind up chewing up the rotor). Otherwise you should be OK for a while.
