Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-06-2004, 10:09 PM
NascarNut NascarNut is offline
Send a message via AIM to NascarNut Send a message via Yahoo to NascarNut
Angry 98 Ram Idle Problems
My 98 Ram Pickup would'nt start this morning, early in the afternoon it started, ran rough for a few minuates, then seemed ok. After driving it about 12 miles this evening it refuses to idle. The odd part is there are no codes. Anyone have any ideas on this one??
Old 12-06-2004, 10:16 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 98 Ram Idle Problems
Clogging cat probably.
My Mopars
Old 12-07-2004, 06:48 AM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
could be a stuck or dirty IAC (Idle Air Control) plunger.
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
Old 12-08-2004, 11:07 AM
Thumbs up
Just wanted to say thanks, Cleaned the IAC and seems to have more HP and idles like a new one (so far)
Thanks for the help!!!!!
Old 12-08-2004, 04:09 PM
BleedDodge's Avatar
Good deal.
My Mopars
Old 12-12-2004, 08:59 PM
TurboSW's Avatar
TurboSW TurboSW is offline
Re: Re: 98 Ram Idle Problems
When you say IAC, are you referring to the 2 throttle body flaps? If so I had the same problem this weekend. I cleaned them and it cured the problem.
Old 12-13-2004, 07:06 AM
nope, the IAC and the throttle blades are tow diffirent things, but both are located on the throttle body.
the IAC is a little motor and plunger that is mounted on the back side of the throttle body. when the engine is ideling, the throttle blades are compleatly closed, and not letting any air into the engine. when the throttle blades are closed, the IAC controls the amount of air getting to the engine. I'll look around and see if I can find a picture or diagram to explain it a little better.
Vehicles:
1987 Grand Wagoneer
