Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 12-06-2004, 10:09 PM
bstephen bstephen is offline
Question Major hesitation under accleration
I am the proud new owner of a 1994 mazda 626 lx 2.0 liter five speed. I purchased the car in poor condition. I have many problems but I will start here. The car starts easy and idles great. When I acclerate past like 1/4 throttle the engine seems to die immediately unless you let back out to under 1/4 throttle and then snaps right back and runs again. If you hold it to the floor it will die. You can drive the car as long as you hold the throttle under 1/4 throttle. It has enough power to drive down the interstate at 60. You just don't have much acceleration to pass and such. The check engine light is not on and everything seems to be great other than this problem mechanically. Please shed some light in my direction I am a new Mazda owner.
Thanks
Old 12-07-2004, 02:36 AM
martin626 martin626 is offline
The only thing I can tell you is....
Have a mechanic look at it.
Good luck man.
Old 12-07-2004, 06:53 PM
lyciph lyciph is offline
Send a message via AIM to lyciph
Re: Major hesitation under accleration
yo wsup man, im getting ready to pick up a 1987 626 turbo Fi, any advice before i get it? and about your problem, did u ever get it fixed? wat was wrong with it?
Old 12-07-2004, 10:14 PM
Mark E M Mark E M is offline
Yea, I just fixed mine... Your throttle position sensor is bad. Get a new one. If you don't know how or where to install it, get help. If incorrectly installed, you'll ruin a new switch, and possibly kill the e.c.m. Hope this helps..Mark
Old 03-18-2005, 02:51 PM
snooker147 snooker147 is offline
Re: Re: Major hesitation under accleration
distributer cap & rotor,
Old 06-02-2005, 11:22 PM
TopSpeed2130 TopSpeed2130 is offline
try tune up oil change and clean fuel injectors with b-12 and pcv valve
Old 06-26-2005, 11:59 PM
dankdog dankdog is offline
its the distributer
