Old 12-06-2004, 09:46 PM
integragsrt integragsrt is offline
Angry cel code 8, tdc sensor
i need some help i have a 96 integra gs-r obd2 of course i had the cel 8 come up so i bouth a new distributor like i reall on all the forums and it went away now three days later it poped up again and my car doesnt want to start i rest it a couple of times and still nothing i went back to my car tryed starting it again and it started but the cel 8 was still flashing i need help...
Old 12-06-2004, 10:35 PM
travagliante's Avatar
travagliante travagliante is offline
Re: cel code 8, tdc sensor
Well id say post in the integra forum? duh!!
You need a new distributor.
TDC,CYL,CRANK angle sensors are theroetically "a part of the distributor" they cannot be replaced. A new dizzy is what you need,
Old 12-06-2004, 11:59 PM
Beater88 Beater88 is offline
No need to be mean...
Integra is just a fancy Civic...
You replaced the Dizzy and it came back, bummer did you get a new one or used one?
Could be something wrong with the wiring or plug.
I have heard that the Honda motors have issues with proper grounding on the dizzy. I was told by several parts people that you must run a ground wire to one of the bolts on the Distributor or they blowup and should run a good ground to the main engine harness ground that is bolted to a waterjacket. Stupid place to put a ground anyway, electrolysis after a while will not allow for a good ground. Though don’t make the mistake that most people make and leave the main ground grounded to the block you will create a ground loop. You should run a wire to the block ground and solder and shrinkwrap to the engine harness ground. Check all your grounds too. Big issues come from this. I always replace my grounds with 4awg wire from the battery to chassis and from chassis to motor, and I got to a tranny bolt, when I get a new car. Maybe overkill but I never have ground issues
Old 03-18-2005, 05:11 PM
MrSmith MrSmith is offline
Re: Re: cel code 8, tdc sensor
Ok this is real old I know. I have an Acura Legend 1990. I have a code 8. so I checked my book and its just as the other hondas are TDC {Crank angle} I replaced my Distributor with a New one/ Out the box from an autopart store. My code went away for about 20 minutes and returned. I read what was said about the ground. Im not understanding were my ground for the distributor is. can someone assist.
