Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 12-06-2004, 09:21 PM
ky4runner ky4runner is offline
Unhappy HELP!low beams dont work
Low beams are not working. Fuses in fuse box ok and lights work on high beam. turn lights work also
Old 12-06-2004, 09:39 PM
sorry
It is a 1999 4-runner
Old 12-21-2004, 04:51 PM
forest_grump forest_grump is offline
Re: HELP!low beams dont work
Most commonly after checking all fuses and jumping voltage to low beam connections on headlamps to make sure you actually have good headlamps it is the turn signal high/low beam assm in colum...can check this using a testlight and look for voltage in wiring from this switch when you go from high to lowbeam and replace if no voltage is seen in low beam mode...goodluck
