Go Back   Automotive Forums Car Chat > Honda > Integra
Old 12-06-2004, 08:40 PM
khienluong khienluong is offline
Engine shakes on first gear!! some advice please
I have an integ ls 1996. My engine shakes on first gear whenever i am accelerating from a complete stop. This only happens whenever the car has been idle for a while or simply when the parts are cold. After drving it for a good 5 - 10 minutes, i dont have a problem. I called a clutch expert and she said it might be my flywheel from accelerating too fast in the past. I think she is right because it shook really bad when i tried to peel out one time. Does anyone know wassup??
Old 12-06-2004, 11:15 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Engine shakes on first gear!! some advice please
the engine and tranny mounts. check em out. if your mounts are good, there is no way for the engine and tranny to be shaking rough.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-06-2004, 11:52 PM
forcefanad forcefanad is offline
Re: Re: Engine shakes on first gear!! some advice please
i think hes talking about clutch chatter...
Old 12-07-2004, 03:03 AM
ok.well i dont know how to check it..so im just wondering is it something critical and is it expensive to fix?
Old 12-07-2004, 11:06 AM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
would bet it is your clutch and or flywheel. if it only does it starting to drive from a stop and it doesnt do it when just sitting there. It is a spring loose on your clutch which you have to replace whole thing or hot spots on your flywheel, which you might as well replace your clutch swhile your flywheel is out, exedy stage1 clutch is only like $115 its the labor thats like $300.
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 12-07-2004, 07:25 PM
ok thanks..and was this caused my accelerating too fast or its a sign the my clutch is gonng go out.. because it runs fine after couple minutes..
Old 12-08-2004, 01:24 AM
gsr916 gsr916 is offline
Banned
Send a message via AIM to gsr916
bad motor mounts would not stop the engine from shaking after 5-10 minutes. bad motor mounts shake even when sittin at the stoplight no matter how long the car has been drivin. also, doesnt seem like a bad clutch would suddenly become a good clutch after 5-10 minutes either... clutch performance even decreases as temperature increases... just like brake pads....
