Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 12-06-2004, 07:51 PM
surfjeepzx surfjeepzx is offline
Send a message via AIM to surfjeepzx
1990 egr sensor location
Hello,
New to this forum and have a quick question for the pros. On a 1990 MGM, 5.0 liter F.I., where is/are the egr sensors located. My Moms car had the "check engine" light on and I pulled a coce "34". Per the code book this shows as the egr sensor. Tried reseting and the code is current which tells me it's a hard fail. I suspect the 2 vacuum switches which are at the rear top of the plenum are the control switches for the egr valve located next to the right exhaust manifold.
I appreciate the help
Old 12-07-2004, 08:28 AM
6502dude's Avatar
6502dude 6502dude is offline
Check out the EGR system before replacing sensor on spec.
Try pulling vacuum on EGR value to determine if it is operational.
Also, check gas recovery tube. It is a thin walled tube and often prone to rust thru, or breaks off at end.
Old 12-08-2004, 06:13 PM
auto trainy auto trainy is offline
Re: 1990 egr sensor location
I think its right at the EGR valve.
