Old 12-06-2004, 07:17 PM
Bill-SILV Bill-SILV is offline
Heated mirrors
I recently traded my 2wd in for a 02 4wd and it has the option of the heated mirrors with the back window defrost. and Last week we had the first heavy snow this year and I noticed that the driver side mirror doesnt defrost but the back and the passanger side does work. Anyone have any ideas on what to look for? Can you take the mirror apart and maybe find a resistor burnt or something? Thanks for your input.
Old 12-08-2004, 02:38 PM
rfgale rfgale is offline
I too have an '02 where the drivers side appears to not work. However, I do know that you can get replacements at any autoglass replacement shop. I would first try cleaning the leads that are on the back of the mirror, or look to make sure it's connected. You'll want to be careful prying the backing plate, as you could crack the mirror. Tilt the mirror so you can see behind, you'll notice the plastic teeth that are grabbing the motor housing. Pry gently, and it should pop off. Replacement will probably cost you $40-50, so try not to break it. If you do need a new one, the part number for the most popular supplier (Burco) is RED2734H.
Old 12-11-2004, 04:37 PM
sparrbq sparrbq is offline
Angry Driver-side heated mirror
I have same problem.
2003 Silv. 2500HD 4x4
Taking it in for warranty repair Tuesday. Will let you know...
Old 12-21-2004, 06:40 AM
Re: Heated mirrors
Dealer said "Mirror Switch" part is on special order mir-kit 16.068a
Old 12-21-2004, 06:50 AM
Great, thanks for letting us know. Now, what did they mean by 'switch'? The actual switch in the dash that controls both the mirrors and backglass?
Old 12-21-2004, 07:03 AM
Re: Heated mirrors
Im guessing just in the drivers side mirror?
as my right mirror and rear window heat well.
Hope this helps out.
Old 12-21-2004, 07:08 AM
Thanks a bunch. I bought my truck used in May, I guess I'll have to see if the dealer will work with me, since they went over it with a fine tooth comb, and it's obviously impossible to test the heated mirrors then. Thanks again, and Happy Holidays!
Old 12-21-2004, 04:44 PM
thanks for letting us know, rfgale let me know if you get help from the dealer on fixing that because I bought mine in november so Ive only had it a month I wonder if they would help me or tell me to get screwed.
