Old 12-06-2004, 06:51 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
No Fire... Need Help
My gremlins been sitting up for a few months, now it wont fire. Has a new coil, wires, cap, rotor, and plugs. Anyone have any suggestions?
77 258 I6
Old 12-07-2004, 02:44 PM
88Rob77 88Rob77 is offline
The gas might be bad.. have you checked that yet?
Old 12-07-2004, 03:24 PM
Forunn Daberator
Re: No Fire... Need Help
That wouldnt have anything to do with it not sparking though.
Old 12-08-2004, 01:22 PM
Oh, I thought you meant just start.
Are all of your wire connections correct?
Old 12-08-2004, 01:26 PM
Forunn Daberator
yeah it seems to be all tight and it all should be right because it ran fine a few months ago. I think its something before the coil, ignition module or something.
Old 12-08-2004, 04:19 PM
carnuck carnuck is offline
unplug and replug the connectors. If that doesn't clear it up, jump wire battery+ directly to the coil + and see if it fires. If not, then likely the ignition box bit the big one. ('77 still has the Presto-no-lite setup?)
Old 12-08-2004, 08:06 PM
Forunn Daberator
some were prestolite some were motorcraft, off the top of my head I cant remember witch mine is, it has been a while sence I worked on this car.
Old 12-08-2004, 08:15 PM
gold box is prestolite
